I just found an ad for this 1959 Wolseley 6/90: Fitted with an unusual factory fitted right hand gearchange: I've never seen anything like that before. Has anybody got any ideas as to why that was available?
1982 Mercedes 280TE
Maybe the old boy it was fitted for needed his left hand free to smoke his pipe and tobacco ? Probably something silly like that Would love to see all the gubbins that make that work underneath as looks interesting to say least
Brian Damaged
West Midlands
Club RR Member Number: 33
Fairly common for the time amongst higher end stuff. The Riley Pathfinder (or Ditchfinder as it was more commonly known, due to its awkward handling) and various Bentleys also had a right-hand floor shifter.
Jul 21, 2014 10:24:58 GMT
Fairly common for the time amongst higher end stuff. The Riley Pathfinder (or Ditchfinder as it was more commonly known, due to its awkward handling) and various Bentleys also had a right-hand floor shifter. I knew older stuff had it, but didn't realise (relatively) modern designs had it too. According to Wikipedia, Series 1 had column shift, and then 2 and 3 had floor shift, found this pic of a LHD car: I wonder if driver's side floor shift was easier for them to link up to the column shift bits when they changed position? I can't find any pics of the actual linkage, but I did find this on a blog by a special builder. the blog itself is here, and from the little look I've had is fantastic nigelhamlinwright.wordpress.com/2014/07/21/more-fabrication/
1982 Mercedes 280TE
Jul 21, 2014 11:21:10 GMT
Wow great sketch above imagine would be a nightmare in terms of bushes and sloppiness when worn Still looks so much better than modern cable change setups though
