People tend to slag them off because they are found in all sorts of things, but a good Rover V8 is a lovely thing. Where I live we have a 1:4 slope inside the car park between levels and I could spend all day just going up and down listening to the noise
HID conversion for your headlamps - awesome lighting power.
People tend to slag them off because they are found in all sorts of things, but a good Rover V8 is a lovely thing. Where I live we have a 1:4 slope inside the car park between levels and I could spend all day just going up and down listening to the noise yeah with you on that, will try a nice built up car park going to make some vids soon
HID conversion for your headlamps - awesome lighting power. good idea, I have a setup in the garage some where? forgot all about it.........
Aug 10, 2014 10:03:42 GMT
Thinking of doing HID conversion on mine eventually but need to get all the other jobs done first. I do remember though that the indicator/dip beam switch in the esprit is weak (they burn out unless you add an additional relay) so I think that would also need changing?
Aug 11, 2014 23:06:25 GMT
Thinking of doing HID conversion on mine eventually but need to get all the other jobs done first. I do remember though that the indicator/dip beam switch in the esprit is weak (they burn out unless you add an additional relay) so I think that would also need changing? yes just about sums up doing any upgrade always another job to add to the list! Charlie are you going to the gathering?
I should be, however just in person, no red panther. Two of the biggest shows (Lotus Elites type 75 are 40 years old this year) and the gathering, and I'm going to miss them both, balls!
Aug 12, 2014 11:37:44 GMT
I should be, however just in person, no red panther. Two of the biggest shows (Lotus Elites type 75 are 40 years old this year) and the gathering, and I'm going to miss them both, balls! are you going to brands on the 17th? I am taking the esprit
That sounds particularly nice!
Aug 13, 2014 10:14:02 GMT
adam73bgt
Club RR Member Number: 58
Aug 13, 2014 10:19:00 GMT
This is just so awesome! Great work, I can't wait to see/hear it at the Gathering
Aug 13, 2014 11:32:22 GMT
Haha love it, now that's just too Bond!
mk2cossie
Club RR Member Number: 77
Aug 13, 2014 13:21:03 GMT
Bookmarked now Is this the same Esprit that is mentioned on Pistonheads about the front caliper brake pipe fittings? If so, what did you work out in the end? Loving how quite the airbags shift the car in that video though
Aug 13, 2014 18:08:19 GMT
Bookmarked now Is this the same Esprit that is mentioned on Pistonheads about the front caliper brake pipe fittings? If so, what did you work out in the end? Loving how quite the airbags shift the car in that video though yes it is, used the top inner bleed as the new feed with a banjo fitting, blanked the original feed with a bleed nipple (nipple cut off) and only have one bleed nipple now. Its a sod to bleed but it works!
Aug 13, 2014 23:20:21 GMT
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
I actually dreamt I was driving around in this last night, playing "On her majesties secret service" by the Propellerheads. Apt.
Such undiluted rampaging want.
Aug 14, 2014 10:34:49 GMT
all I dream of is having it finished or at least all the little unfinished jobs checked off and done. Its a LOTUS so its never going to be!
ulver
Aug 14, 2014 19:08:12 GMT
Love it, having had a TVR Chimaera before, the urge to get something with a nice Rover V8 is strong..
'99 Alfa Romeo 156 2.5 V6
Aug 16, 2014 20:56:16 GMT
taking it to Brands Hatch tomorrow
