Jun 29, 2014 21:44:51 GMT
still motd but breaking becuase Power steering pump leaks engine mount is split , heater only comes out of vent, Rusty sills 15 inch alloys x 5. With 2 very good tyres, 3 legal tyres. update: NOW SCRAPPED
Last Edit: Sept 2, 2014 0:12:11 GMT by datman
kenb
Jun 29, 2014 21:54:06 GMT
The Ford Anglia boys will give you good money for the ali sump, windage tray, oil pick up pipe, and the four centre mains cap bolts that the w/tray bolts too. As it allows you to fit a Zetec in an Anglia easily.
don't bin those bits!!
thanks, surely any zetec has those bits?
kenb
No Anglia's/Cortina's need a silvertop front bowl sump and that was only fitted to Escorts like yours and the RS1800 fiesta. Mondeo had a mid bowl sump and the later Blacktop sumps fitted to Focus although front bowl need a lot of work to get them to work properly.
Last Edit: Jul 8, 2014 19:55:08 GMT by kenb
Jul 11, 2014 12:42:57 GMT
ah cool thanks. Can that stuff be removed with engine in the car and is it worth me doing it, what would they be worth?
kenb
Jul 11, 2014 16:02:49 GMT
Try advertising on 105speed.com forum when you've got them out before you go ebay. or give me the nod and I'll put on an advert for you.
Yes as far as I know you can get everything out with engine in car.
Last Edit: Jul 12, 2014 4:01:09 GMT by kenb
Jul 11, 2014 18:34:42 GMT
If you could drop an ad on that would be awesome, if i get a taker i will remove them from the engine:)
kenb
Advert on for you. I put a link to here so hopefully they find it.
dalek
Jul 12, 2014 10:26:52 GMT
The Ford Anglia boys will give you good money for the ali sump, windage tray, oil pick up pipe, and the four centre mains cap bolts that the w/tray bolts too. As it allows you to fit a Zetec in an Anglia easily. don't bin those bits!! Hello, thanks to Kens advert on 105speed here i am :-) I'd like those bits please if you can post them ? Cheers Craig
dalek
Jul 15, 2014 13:43:41 GMT
You have a pm datman
Jul 17, 2014 23:02:08 GMT
Parts removed today.
kenb
Jul 17, 2014 23:30:41 GMT
Glad you got it sorted.
gavs1
Hi I'm after the cast bracket that houses the alt and power steering pump, thanks,
turbom
Hhave you still got the fuel filter bracket???
Jul 21, 2014 15:54:56 GMT
sump posted. scrap man might be coming for this today so not sure about those bits, where is fuel filter on these?
turbom
Jul 21, 2014 19:34:40 GMT
Either engine bay or underneath by the tank???
ok found underneath, would need to get under there and see how easy it removes, what would you offer for it?
turbom
Jul 22, 2014 12:23:58 GMT
£5 +p&p?? sound ok???
dalek
sump posted. scrap man might be coming for this today so not sure about those bits, where is fuel filter on these? Thanks to both of you
Jul 23, 2014 13:27:01 GMT
sorry too rusty
