OK, shamless one here, I have a bloomin great Oldsmobile with a trashed autobox. Getting said big heavy box out of said big heavy car is going to involve some moderate arze. Pillock & I had a little looksie at it last night and although the Olsmobile forum says the engine really should come out the top with the engine/trans attached we reckon theres space to get to the bellhousing bolts OK from top/bottom with the engine in place and drop the box from underneath. (to quote Pillock - "nothing that a well trained baby couldn;t get to anyway") I have not set a date to do this yet, having wee small child at the mo doesn't help but damn this has to be done. ideally next few weeks, one weekend. I reckon 3 or 4 of us (for the weight, the "here hold this that end" and the crack factor) would breeze the job no problem. If anyone fancies coming on down and lending a hand there will be tea & biscuits and swearing. Anyone with previous experiance of getting a TH400 out of a mid 60s Olds particularly welcome. LMK and I'll let you know when its going to be so you can roll out your excuses then
If anyone fancies coming on down and lending a hand there will be tea & biscuits and swearing. haha great sentence there mate, would help but too far yet again!!
I'd be up for that AK. I'm in Notts so it won't be too far to travel. Not a clue about Yank stuff, but can lend my general spannering / chin stroking / tea brewing abilities. Most weekends I'm free, but best put in a disclaimer incase I'm elsewhere when you decide to do it!
Dez
Club RR Member Number: 34
just a little note, the input shaft on a th400 is about 4-5" long, so youll need to be able to slide the gearbox back a LONG way for it to clear the torque converter. don't know if that will be a problem or not on your car- you may have to undo the motor mounts and stuff so you can tilt the tail end down sufficently?
useful info, thanks. wiggle the motor upwards and home we don;t hit the floor....
If you werent so far away I would have had apop down
Mr S
10-4 Good buddy.
If it's a weekend when I'm free, I'd be more than happy to lend a hand. I'm only in Ilkeston, so just down the road really...
Cheers, Martin
filmidget
East Midlands
Mostly Lurking
Last Edit: May 5, 2007 9:55:54 GMT by filmidget
'79 MG Midget 1500 - Still patiently awaiting attention '02 Vauxhall Astra 1.8 Elegance(!) - Better than you might think '03 Mazda MX5 - All new and shiny looking (thanks to Antony at Rust Republic) '09 Renault Clio - Needs to go.
cheers guys
madmart
love is: valvebounce in top gear
just a little note, the input shaft on a th400 is about 4-5" long, so youll need to be able to slide the gearbox back a LONG way for it to clear the torque converter. don't know if that will be a problem or not on your car- you may have to undo the motor mounts and stuff so you can tilt the tail end down sufficiently? doesn't the torque converter come off with the box?
Lopez
East Midlands
I'm just outside Ashby, weekends are tight in May but evenings would be fine - I haven't worked on a yank tank since my Dad's Mustang.
PS was that you in Practical Classics this month?
tigran
In rust we trust. Amen.
Club RR Member Number: 142
If for some reason it's in june then I'll be about - but i've got mad ammount of examz on in may.
OK, shamless one here, I have a bloomin great Oldsmobile with a trashed autobox. Getting said big heavy box out of said big heavy car is going to involve some moderate arze. Pillock & I had a little looksie at it last night and although the Olsmobile forum says the engine really should come out the top with the engine/trans attached we reckon theres space to get to the bellhousing bolts OK from top/bottom with the engine in place and drop the box from underneath. (to quote Pillock - "nothing that a well trained baby couldn;t get to anyway") I have not set a date to do this yet, having wee small child at the mo doesn't help but damn this has to be done. ideally next few weeks, one weekend. I reckon 3 or 4 of us (for the weight, the "here hold this that end" and the crack factor) would breeze the job no problem. If anyone fancies coming on down and lending a hand there will be tea & biscuits and swearing. Anyone with previous experiance of getting a TH400 out of a mid 60s Olds particularly welcome. LMK and I'll let you know when its going to be so you can roll out your excuses then If I was closer I'd do it, as I have plenty of previous yank experience including dropping the tranny out of one of my dodge pickups to swap in a new torque convertor, with the help of only one other, and then only for the first half of the operation (we got it apart, put the new torque convertor in, and then realized that the flexplate bolt pattern was completely different that I would have to go back to the breakers to get the flexplate as well. You should be able to do lift it with a floorjack and one person to steady it. This all reminds me of a funny storry I once heard. A guy is changing the gearbox on his Dodge Coronet. It's a manual A-833 which has a cast iron case and probably weighs as much as your typical autobox. Anyways he's got it all unbolted and is holding it up underneath the car while lying underneath. While he's benchpressing abotu 90 lbs of mopar gearbox, his cat spies a comfy place to rests, and proceeds to lie down on his chest, leaving him stuck, underneath the dodge, holding the transmission while trying to persuade the cat to leave. Moral of the story. no kitty doors on your garage.
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
PS was that you in Practical Classics this month? yes
canuck
if it aint broke, fix it till it is!
I'll happily lend a hand assuming I'm free mate! Let me know when, and I'll pop over!
Matt
If it aint broke...Fix it till it is!
If this offer is still open in a few weeks, I'd be game Probably bring my dad too, he's a whizz at this kind of stuff ;D
May 10, 2007 14:16:17 GMT
Blimey, I'm going to have to put a shipping order in with the chippy of you all come LOL.
as soon as I know when, I'll let people know. Want to wait until the little'un is a little more settled or Em will kill me.
