Brian Damaged
West Midlands
Club RR Member Number: 33
Jun 22, 2014 14:24:46 GMT
Appliance Wire Baskets, would have originally looked thus: Wire 'baskets' bolted onto a centre cap, AFAIK. Quite common over here in the early 1980's. Seth of this parish has/has had a set the same, sans baskets, on his Minx Estate.
Dez
Club RR Member Number: 34
Jun 22, 2014 14:46:07 GMT
appliance probably made and sold more steels than they did alloys- their most popular lines were all chromed steel- the cragar-alike 5 spokes(also available in smaller 4 spoke sizes too), the steel slot-mags, the wiremags, the true wires they made, chrome smoothies, as well as what we know as 'wellers' over here.
Last Edit: Jun 22, 2014 14:46:45 GMT by Dez
Jun 22, 2014 15:22:10 GMT
I like those Paul H
Jun 22, 2014 15:54:05 GMT
Nice find. It's be worth checking very carefully that they *are* 4x100 - there's a good chance that they are in fact 4x4" (101.6mm). It's not a big difference, but it's enough to cause trouble in terms of snapped studs etc. Wobble bolts would be fine, but you'd need spigot rings to centre the wheels. ...are aluminium.
Dez
Jun 22, 2014 15:56:56 GMT
they are. i meant the wire baskets!
Seth
Jun 22, 2014 16:07:40 GMT
I wouldn't be grumbling if I'd just bought those! Looks like they'll work well with those centre caps.
Jun 30, 2014 18:57:13 GMT
Better measure from outer-to-outer
Click picture for more
