sowen
Club RR Member Number: 24
May 11, 2014 21:10:26 GMT
Last Edit: Aug 19, 2014 15:57:06 GMT by sowen
fer4l
Testing
Club RR Member Number: 73
May 11, 2014 21:53:08 GMT
This looks full of win to me
THE_Liam
Yorkshire and The Humber
If at first you don't succeed... HAMMERS.
May 12, 2014 10:50:06 GMT
This looks potenially amazing!
May 12, 2014 11:16:00 GMT
I love P6's and I love 'fast' so I can imagine that I'm going to love this too...!!! Please do keep us posted...
***GARAGE CURRENTLY EMPTY***
sowen
May 12, 2014 19:56:21 GMT
sowen
May 12, 2014 21:43:13 GMT
adam73bgt
Club RR Member Number: 58
May 12, 2014 21:58:19 GMT
You're saying supercharger or turbocharger... Why not both?
sowen
May 12, 2014 22:12:02 GMT
You're saying supercharger or turbocharger... Why not both? I think the old V8 will struggle with just the one, running both really wouldn't last long but then I wouldn't know for sure if I didn't try
sonus
May 13, 2014 11:26:01 GMT
What a cool sleeper this will be Have you looked into usng TVR manifolds to mount the Turbo infront of the engine?
sowen
May 13, 2014 11:48:37 GMT
What a cool sleeper this will be Have you looked into usng TVR manifolds to mount the Turbo infront of the engine? That's not a bad shout, for ease of installation and to get it running in one form or another it needs the radiator up front so no room there at this moment in time. I did look into mounting it at the back behind the engine, but routing the exhaust looked a bit too complex, although if it ends up evolving mounting the radiator elsewhere could always be an option
sonus
May 13, 2014 12:08:03 GMT
village
Always carries a toolbox. Because Volkswagen.......
May 13, 2014 12:41:14 GMT
With a diesel being more thermally efficient that a petrol, will the Disco rad be up to the job of cooling a breathed upon V8?
"The White Van is strong with this one...."
Chris "Chesney" Allen 1976-2005 RIP
79cord
May 13, 2014 13:18:54 GMT
Great to see the progress/ideas developing & some of the earlier/alternative ideas from your other P6 being renewed.
sowen
May 13, 2014 17:09:25 GMT
I remember seeing that one, the supercharger is sunk very low into a custom baffled inlet manifold which is entirely possible with the lack of distributer on the front of the V8. I have enough spares that I could do something similar, will have to start messing about trying some odd spares again With a diesel being more thermally efficient that a petrol, will the Disco rad be up to the job of cooling a breathed upon V8? There's only one way to find out and that's to try it! The core is significantly deeper, similar height but not quite as wide. I've justified buying it as I have other vehicles it would fit if it proves to be inadequately too small. Great to see the progress/ideas developing & some of the earlier/alternative ideas from your other P6 being renewed. The blue P6 evolved in a certain way, it had to be more of a driven car rather than a special occasion toy which meant I had to refrain from going all out on it. This time it's just another project/toy, so anything goes (within reason!) I'm now thinking, what would I have to do to a Rover V8 to get it to handle respectable boost levels, and how budget/diy could it be?
sowen
May 19, 2014 11:56:15 GMT
I had a trip with a mate to my local scrappy Smiths of Bloxham, and we gutted the suspension off an old Scimitar. My mate wanted the front hubs and I had the back axle for the P6. The Salisbury 4A is a heavy old beast, has the Watts linkage I wanted, and the brakes and handbrake look to only require minor work to make good again and join into the P6. It's 57" wide face to face, and I think the optimum P6 width is somewhere around 51"-52", so I've begun researching narrowing, and what ways I can convert the 4x4.5" pcd to 5x5" to suit my wheels and keep a relatively stock appearance. I'm sure there are better more suitable axles nearer the width I want, but the Scimitar has the suspension mounts I can use as datum points to make the P6 suspension arms fit. I'm now in the process of stripping it down to assess it's condition, and see what work is required to bring it up to standard
sowen
May 19, 2014 21:23:07 GMT
I pulled the rear cover off the diff to see what I've got, and for an old axle it appears quite clean inside and still full of axle juice! Looking at the Watts linkage off the Scimitar, it looks like a nice neat and narrow unit that will fit in the space which is presently occupied by the DeDion tube. I think a frame could hang off the old differential mounts at the top, then braced against the chassis rails and lower boot floor would be sufficient. With a little help I've re-measured the Scimitar axle width and the P6 axle width. The Scimitar is about 56.5" hub face to face, and the P6 approx. 56.25" hub face to face. Those measurements are suspiciously close so I need to check again, but if they are anywhere near that close then obviously there's no need for narrowing the axle, just adapting the different pcd's which I'm beginning to formulate a possible plan for...
sowen
May 20, 2014 21:55:18 GMT
With a burst of enthusiasm I've removed the DeDion back axle from the P6 and rolled the Scimitar axle in underneath Plenty of room between the axle case and the boot cavity to mount the Watts linkage The top links line up with the outer face of the upper arm mounting on the Scimitar axle, couldn't have asked for it to sit any closer and better if I wanted! The lower arms are the same, the outer face of the axle lower arm bracket lines up as near as perfect as could be possible too! What I'm thinking is moving the inner faces of the upper and lower mounting brackets to suit the P6 suspension arm bush widths. Using the existing axle suspension mounting holes I plan to use them as the datum points to overlay new plates to locate the axle in the correct orientation. Measuring the P6 axle once removed it appears to have shrunk again to near 55.75" max width against the Scimitar axle at 56.5" wide. Now the Scimitar axle is in the workshop I'm in a better position to strip the hubs down to measure them up, and get on the the adaptation work I need to do to fit the 5x5" pcd wheels.
May 21, 2014 20:38:52 GMT
Jensen Interceptors use a 4HA axle with a 5x5" PCD. Personally, I'd have gone for a narrowed SD1 axle, which has a pretty neat Watts linkage built into the diff cover. As for the engine, I'd go supercharger every time, if only for the whine.... Keep up the good work, I do like a P6
sowen
May 21, 2014 21:19:11 GMT
Jensen Interceptors use a 4HA axle with a 5x5" PCD. Personally, I'd have gone for a narrowed SD1 axle, which has a pretty neat Watts linkage built into the diff cover. As for the engine, I'd go supercharger every time, if only for the whine.... Keep up the good work, I do like a P6 I spent some time umming and erring over what axle I wanted to use, obviously there is no single perfect axle, so the end choice would always be a compromise. Jensen axles I'd assume are pretty thin on the ground, and would be likely to be expensive as and when they pop up. The SD1 axle is an obvious choice being off the next Rover model and also the correct pcd, but it is completely unsuitable for what I have in mind. It has a long pinion extension which is incompatible with my plan to retain as much of the stock P6 suspension as possible. The hubs and driveshafts I believe are one piece units which again would be more time and expense to shorten. My shortlist was down to MGB or Scimitar depending on availability, and being that a mate was after some Scimitar parts and it seemed like the best compromise at the time, that was it! The Scimitar Watts linkage is easily adaptable, or I'll end up copying it and making my own completely from scratch. I have been considering having the single central mount attached to the bodyshell and the two arms reaching out towards the hub ends? Now I've got the axle, it appears it only requires simple modifications to the suspension mounts, and modifying the hubs for the different pcd to get it fitted to take the weight The more I look at the supercharger the more I want to use it, though what is also on my mind is ditching the Rover V8 entirely and searching for a Ford or Chevy small block to use in the future...
sowen
May 24, 2014 21:54:40 GMT
I've got the driveshafts off the axle, very difficult as I can't shift the hubs off the shafts yet. I cut the bearing off one to get it in my 12 ton pipe bender, ended up bending the frame! With the brake backplates out of the way I could look at the mounting of the axle better, and compare it to the standard DeDion mounting points. Taking some rough measurements using the Scimitar lower suspension arm mount holes the axle would sit about 1.5inches lower, so would push the back of the car up. Factoring in the driveline not being body mounted I estimate a potential rise of 2" in ride height at the rear. So far on the axle mounts the lower bracket has been widened by cutting the inner face off and welded back on further in to retain the existing holes, and the upper mounts have been extended upwards. They still need drilling, and I also want to have the axle case grit blasted then the suspension mounts can be boxed in and some extra reinforcing plates welded on top to finish. The axle ready for trial fitting The new axle mounts The axle temporarily bolted in place except for the upper mounts at full suspension drop
