Sept 9, 2015 18:15:00 GMT
What I can see without much garage digging is:
Pair of Clear side repeaters, two standard side repeaters (1 flat and 1 domed topped, think the difference is UK and Japanese), steering wheel, Dissy cap, rotor arm and leads ( used but good), standard reversing light,.
I know I used to have a stainless back box but it might have been dumped in my last garage move.
Last Edit: Sept 9, 2015 18:16:56 GMT by topdeck
Best Served Chilled
Sept 9, 2015 20:45:59 GMT
That's quiet a collection you have there! Well if you pile it all up I can either collect it from you or sling you some cash for postage? Thanks a lot! (Clear side repeaters sounds good)
Sept 9, 2015 21:45:59 GMT
Happy for you collect it if you're around this way ( Evesham, Worcestershire).
Last Edit: Sept 9, 2015 21:46:39 GMT by topdeck
Best Served Chilled
Sept 10, 2015 9:03:40 GMT
I don't travel that way often but there is a kei car meet on the 27th of September when I will be going up that way. Up at the heritage motor museum.
Sept 10, 2015 21:29:07 GMT
unfortunately I'm away that weekend.
Best Served Chilled
Sept 11, 2015 6:38:34 GMT
Hahahhaha no problem! Well once you've located and stock piled it all for me give me a shout and I'll send you some cash for the postage If that's ok? Thanks very much
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 11, 2015 7:30:30 GMT
Lovely work on this capp and the engine bay detailing looks smashing too. I have a soft spot for keis Are you waiting for it to rain before challenging Takumi?
Sept 11, 2015 17:22:53 GMT
I am growing more fond of the kei cars as I described more and more! I am tempted to get a collection of kei cars one for every event! Takumi- translated to artisan (if Google is correct)
vanpeebles
Sept 12, 2015 8:02:32 GMT
Hehe this was the Takumi (Fujiwara) I was thinking of, might be some inspiration for you here:
I owned a Daihatsu Mira Classic Turbo for a while and loved it, it was a similar size, 659cc but with 4wd too!
Last Edit: Sept 12, 2015 8:04:15 GMT by vanpeebles
Sept 12, 2015 13:00:13 GMT
A very happy child today
Sept 12, 2015 16:44:53 GMT
Hehe this was the Takumi (Fujiwara) I was thinking of, might be some inspiration for you here: I owned a Daihatsu Mira Classic Turbo for a while and loved it, it was a similar size, 659cc but with 4wd too! Is not had a chance to fully watch this! I will load it on the wide screen on my tablet later and watch it! Looks epic! I question how do we 1) find the time to find these and watch them! And 2) have the time to create these! Cheers for the link tho!
So some bits came through the post. Fitted it straight away. Now all I need is the new spark plugs so I can fit my bleed valve and adjust the boost to around 1Bar
Last Edit: Oct 2, 2015 13:05:50 GMT by crazyed
So I fitted my bleed valve ..and new hotter rated spark plugs! Running just under 1Bar boost. I could probably bring it up to about 1Bar. But that's tinkering time I shall do that later.
The Rust-aration .... may begin. I have finally removed the rear subframe to be greeted with the horrors I'd prayed not to see. - at this stage I shall be asking members for help and advice. A large amount of fabrication looks like it's needed.
Sept 5, 2017 10:28:15 GMT
My advice:
Clean all the rusty metal up with wire brush on drill or similar (filthy mucky job and make you wear all the h&s gear).
Repair one area at a time trying not to weaken the structure too much.
Cut the rust back to good sound metal, in the long run may look drastic but one large patch is far easier than lots of small ones on thin rusted metal.
Take plenty of close up pictures, its easy to forget how it looked originally after a few weeks away.
Sept 5, 2017 10:31:17 GMT
Oh and get the fuel tank off and storred well away from where you are welding, also make sure you check for fires on the other side of what you are cutting or welding, someone else to fire watch is ideal.
Sept 5, 2017 13:58:03 GMT
Got you Kevin Iv done some rustaration before. Petrol tank was next on my agenda. Then I will wire wheel it all off and then contemplate my life decisions.
ozzy
Sept 5, 2017 19:59:04 GMT
love small cars and would love to own one of these. its just like a smaller mx5
1985 GMC camper family wagon 1989 nissan sunny 1994 fiat cinq my boys car
Sept 5, 2017 20:04:16 GMT
Mines for sale, advert to follow when I have a sec.
no car, no garage, but the garage is coming oh yes!
