Del
Apr 21, 2014 17:30:35 GMT
Just very occasionally, I've heard a loud rattle when starting the Granada from cold, which stops very quickly and there's a squealing belt at low revs. But today, the rattle was persistent (although not consistent), battery light was flashing on and off, belt squeal was also persistent and power steering is heavy at some points. After a quick look under the bonnet, it looks like a vibration from the crankshaft pulley at the front of the engine. Is this likely to be just the pulley being loose, or something more dramatic (and therefore expensive)?
Last Edit: Apr 30, 2014 14:57:48 GMT by Del
will930
Decked K11 Micra - RetroRunner Mk2 Golf
Apr 21, 2014 18:21:47 GMT
It's sounds to me as if your harmonic balancer may be kaput if you have one!
Essentially the inner part that bolts to the crack and the outer part where the belt goes can be joined by rubber. If that's knoackered and slipping it can cause a whole manner if strange happenings, but some advice don't replace with some after market solid one as these can cause even more issues,replace like for like imo
But these are on cars I've worked on and my experience having never touched a car like yours I cannot be sure!
A way to check is crawl undercar with a prybar and gently see if the outer part has excessive play!
Del
Apr 21, 2014 19:03:38 GMT
I've seen mention of that being a known issue on the 2.5 diesel engine, so it's certainly a possibility.
Apr 21, 2014 22:06:18 GMT
I've got the same issue on my 2.5 Granada, keep meaning to price up a pulley.
Del
Apr 24, 2014 19:21:28 GMT
Where's the best place to get one? Local factors can't get them, Burton's don't have them, none on eBay (unless I'm missing something). Would one of the companies that advertise in Classic Ford or Retro Ford be the best bet? It looks like I have an N9 engine according to the VIN plate, Wiki says there's N9C/N9E/NSE/N9D. Is there a major difference between these?
Rich
Club RR Member Number: 160
Where's the best place to get one? Local factors can't get them, Burton's don't have them, none on eBay (unless I'm missing something). Would one of the companies that advertise in Classic Ford or Retro Ford be the best bet? It looks like I have an N9 engine according to the VIN plate, Wiki says there's N9C/N9E/NSE/N9D. Is there a major difference between these? Tried calling your local ford dealership? they will also be able to help with what part fits. Worst case scenario is that they will be NLA.
Del
I've had 'issues' with them in the past so they will will be the last resort.
Apr 25, 2014 12:10:48 GMT
Sounds painful.
Del
Apr 25, 2014 13:48:51 GMT
After two hours on the phone and online, it looks like Specialised Engines in Grays may have come to my rescue. Bit concerned of the apparent rarity of the engine, a number of comments along the lines of 'can't remember when I last saw one of them', which doesn't bode well for anything else I might need in the future. Oh for a driveway/garage where I could store a spares car!
Del
Apr 25, 2014 15:53:35 GMT
Back to square one SE's system apparently says they have three. They can't find any of them. Now relying on responses from those 'we ask all the suppliers' websites.
Rich
Apr 25, 2014 17:25:22 GMT
Back to square one SE's system apparently says they have three. They can't find any of them. Now relying on responses from those 'we ask all the suppliers' websites. So yea. Still can't understand why you don't try calling the original manufacturer of your car's franchised parts department and asking if they can still be got it's gonna be the easiest way to get one.
Del
Apr 25, 2014 17:30:18 GMT
I think I'm going to have to now. They've just been so incredibly useless in the past that I really don't hold out a lot of hope...
bortaf
Apr 25, 2014 20:54:26 GMT
I'll sort the part and finis code out later for you, so you can go armed but TBH i think the sierra owners club is the best bet for a S/H one/ cant find one at all on M/C for the DOHC ? i'll try the microfiche in the morning when i get to me yard
Last Edit: Apr 25, 2014 22:23:08 GMT by bortaf
R.I.P photobucket
Del
You are a gentleman and a scholar After some extensive searching, I *think* the part number might be 1020834, but would be nice to get it confirmed.
Del
Apr 28, 2014 11:03:25 GMT
Just got a call back from the local dealer... SIX HUNDRED AND FIFTY-SIX POUNDS!!!
Del
Apr 28, 2014 12:00:03 GMT
Looks like GS Escorts have come to the rescue, with a s/h pulley from an XR4x4. Touch wood that it is right, but for £20 posted, I'll take the risk!
Del
Apr 29, 2014 18:47:10 GMT
GS have managed to knacker the pulley getting it off the engine. Back to square one
Del
Apr 30, 2014 15:02:36 GMT
bortaf
Apr 30, 2014 21:47:05 GMT
microcat doesn't even show that part so i cant help there i'm affraid I "think" the pully comes with the crank, that's why Ford quoted so dam high ?? MC doesn't show the V6 vibration damping pully either? only the 2.5 Di one, strange that one have you tried the sierra owners forum ?
Last Edit: Apr 30, 2014 21:49:42 GMT by bortaf
R.I.P photobucket
Del
I've spoken to a breaker in Charlton that reckons he might have one. I'll pop down there at the weekend, then hit the forums after that. I've found that the part number is 6189834
