Apr 15, 2014 18:03:48 GMT
![http://www.datman.co.uk/rr/nvlogs1.jpg](http://www.datman.co.uk/rr/nvlogs1.jpg) I imported this 44 year old 1 ton pickup from Nevada recently, its never had paint, weld, filler or anything. Its rock solid and very straight. I have however had the bench seat completely reupholstered and has had the door cards retrimmed in matching vinyl. (Just the seat was £450) A lot of mechanical work has been done and it has had lots of new parts (rubber things mostly like suspension parts, brake seals, pipes, tyres etc) so this is now a working useable practical truck. We have converted the lighting to UK spec too. Passed MOT with no advisories. UK registered (J reg) Years tax. (Free tax of course) American style pressed metal numberplates 1.6 OHC engine. Manual. Very unmessed with truck , even the original AM radio, package tray and rear bumpererttes at still there. Rated to carry 1 ton. Very useful classic truck. £4500
Last Edit: Sept 24, 2014 17:04:52 GMT by datman
c0llis0n
K11 Enthusiast
May 19, 2014 22:32:51 GMT
Negotiable on price?
Sent from my XT1032 using Tapatalk
May 21, 2014 12:09:15 GMT
Would need to be pretty darn close on the price due to the amount of time, work and new parts this has had, i'm not exactly going to get rich on this one. Could have cut some corners but I like things to be right.
Last Edit: May 27, 2014 2:14:54 GMT by datman
Here's a list of what I've done on this. It hadn't run for many years before I got it.
Fit battery clean carb jets, needle valve blocked unseize handbrake linkage, lube lh rear cable left rear brake adjuster seized, strip,lube replace choke cable replace distributor and fit new points wipers seized , strip/lube pivots headlamp dip switch dodgy, clean contacts LH top arm rubbers replace RH top arm rubbers replace grease idler, kingpins, bottom bushes replace window crank unseize front brake adjusters, check shoes, adjust. replace tyres replace steering wheel fit screen washer bag and pipe change wheel rim reupholster seat make new door cards. remove temporary fuel pipe because original pipe blocked (unblock) missing a wheel nut (found one) clean seatbelts fuel sender not working and not sealing. clean, fit new O ring. water in fuel tank - dry , clean. rh rear brake check and adjust lh rear brake adjust adjust handbrake cables skim rear drums replace rear shock bottom bushes replace rear brake hose replace both front brake hoses air box missing . found one replace fuel pipe to carb replace fuel filler door screws replace front tie bar bushes replace antirollbar link bushes horn track not connecting. Adjust switch. convert front lamps steering box oil top up fit a rear view mirror convert rear indicators to orange fit a battery clamp install new glass run LH instal new glass run RH replace wiper blades repair tailpipe replace rear spring shackle bushes MOT register order plates
Jun 11, 2014 15:02:34 GMT
If you are overseas I can collect you from train station or airport and you can drive this home.
Aug 24, 2014 19:15:41 GMT
bump
Aug 31, 2014 15:55:55 GMT
Make me an offer as I don't want this sitting outside all winter.
Aug 31, 2014 19:43:49 GMT
this truck has been stuck in my head for a few months now Will and i'm doing what i can to sort some cash out. my brother is hopefully getting the cash together to buy my b120 and if that happens i will be on the phone to you.
Sept 3, 2014 12:26:58 GMT
Nice one. Got a viewing Friday just to let you know.
Last Edit: Sept 3, 2014 13:35:23 GMT by datman
Sept 3, 2014 19:25:09 GMT
i fear its not going to come together in time for me but good luck with your sale. i'll have to see what else you will part with once ive got some cash sorted.
Sept 24, 2014 17:05:46 GMT
Sold to RR member.
Last Edit: Feb 18, 2015 14:18:55 GMT by datman
