I need to clean up a diff, It will fit in y blast cabinet, my question is has anyone left it all as one unit and cleaned up with no ill effects?
Is it a sealed independent diff like Herald, MX5, Sierra, BMW etc or just the "pumpkin" from an beam axle ?
Paul h
v8ian
are we talking gears/mechanical bits or case??, gears etc are a nono, as you will cut thru the ground surface, even rusty gears should be considered scrap,.... Casings should not be a problem, as long as you seal it from getting grit into the oily bits, breathers need to be sealed, and I don't like directly blasting bearings or seals, that can damage them or leave grit attached to them and case problems at a later date.
It is a casing fully made up, bmw
