fred
WTF has happened to all the Vennies?
kinda depends who you go to, main kwik fit and franchise garages will turn you over on anything the small independent ones will (usually) work a way out to pass it, Ive had cossie powered Cortinas, de catted Toyota monster trucks, etc.. Just be nice and honest, and offer to make the tea And don't get huffy when they point things out, be humble, like when a policeman pulls you over, humbleness gets you out of many scrapes
'79 Cossie ran Cortina - Sold
2000 Fozzer 2.0 turbo snow beast
'85 Opel Manta GSI - Sold
03 A class Mercedes
Looking for a FD Ventora - Anyone?
I was always under the impression a spare was testable but I'm wrong. Regarding seatbelts though, if the rear seats are removed and so are the belts then they can't be tested. I used to have a caged up road legal track car. No passenger seats at all with all belts and buckles removed, and it always passed.
mdw
Quick update! The car now has an MOT, the tester input it on the computer as having an engine from 1989 and Roberts your mums brother! To begin with they did try to tell me I'm wrong but after going away to check they agreed! So here's some old pics of the car in question, and thanks to the collective knowledge found on here.
1989 VW Caddy 1993 BMW 316/2.5 Touring 1985 BMW 316 (e30) 1984 BMW 316 (e21) 1992 VW Passat 1984 Porsche 924 - SOLD 1985 Volvo 340 GL - disfigured Now cubed 1990 BMW 318i - Sold 1989 BMW 535i SE - executive express SOLD
kinda depends who you go to, main kwik fit and franchise garages will turn you over on anything the small independent ones will (usually) work a way out to pass it, Ive had cossie powered Cortinas, de catted Toyota monster trucks, etc.. Just be nice and honest, and offer to make the tea And don't get huffy when they point things out, be humble, like when a policeman pulls you over, humbleness gets you out of many scrapes If Kwikfit are failing cars for having a bald spare or anything that shouldn't be checked they need reporting to VOSA, all tester have to adhere to the same rules, okay so there is to some extent a 'personal opinion' if something fails or gets an advisory but if they are failing on items that are not even checkable they should have the book thrown at them.
fred
kinda depends who you go to, main kwik fit and franchise garages will turn you over on anything the small independent ones will (usually) work a way out to pass it, Ive had cossie powered Cortinas, de catted Toyota monster trucks, etc.. Just be nice and honest, and offer to make the tea And don't get huffy when they point things out, be humble, like when a policeman pulls you over, humbleness gets you out of many scrapes If Kwikfit are failing cars for having a bald spare or anything that shouldn't be checked they need reporting to VOSA, all tester have to adhere to the same rules, okay so there is to some extent a 'personal opinion' if something fails or gets an advisory but if they are failing on items that are not even checkable they should have the book thrown at them. No not that sort of thing, I mean things like different engines in cars, the independants will try to work a way out, unlike the big corporate ones, which will usually say nope. and with little things like headlight alignment, one l go to will sort it out if they can during the test, and will change duff bulbs without giving a fail for them which the big branch ones would never do, as they are on targets
03 A class Mercedes
oops, sorry Fred I misunderstood you, yes you are spot on with that. my guy will change bulbs/ wiperblades and I have even known him to let a customer change a damaged tyre so it would pass.
Mar 14, 2014 12:52:23 GMT
Quick update! The car now has an MOT, the tester input it on the computer as having an engine from 1989 and Roberts your mums brother! To begin with they did try to tell me I'm wrong but after going away to check they agreed! So here's some old pics of the car in question, and thanks to the collective knowledge found on here. Glad to hear you got it sorted in the end, as an aside, surely if you have the correct engine serial number/size/no. cylinders on the V5 this should be a lot less of a problem because it will be obvious that the engine is not original to the car and hence should be tested to different regulations? Also it is important to have the right information on the V5 for insurance and various other purposes... Just a thought is all :-)
