marinacoupe
Marina Coupe, Triumph Stag
Are they front and rear cable brakes in the picture of the central part of the chassis, or are they some kind of tension based chassis stiffener?
Feb 28, 2014 11:06:08 GMT
The cables are part of the hero-spec braking system
crahel
Feb 28, 2014 12:19:45 GMT
Good looking steel rims, Do you have the body.
1973 Lancia Fulvia s2 coupe (sold) 1998 Audi a4 sedan (sold) 2000 Nissan maxima (sold) 2007 Audi convertible.
Feb 28, 2014 13:09:44 GMT
no body or engine/box, giving me the freedom to built it how i wish with the guilt. i do want to keep was much as possible, so aiming to the keep the brakes and rear axle as is, hence going for a modern 3 pot engine under 100bhp.
Currently i'm investigatng the vauxhall 1.0L x10xe-z10xe-z10xep engine family coupled to a ford rocket box.
mudpud
Feb 28, 2014 13:49:23 GMT
OOh Er! 100 HP and cable brakes,better place order for industrial underpants, possibly in brown! Keep Posting, watching with bated breath.
Feb 28, 2014 14:28:56 GMT
OOh Er! 100 HP and cable brakes,better place order for industrial underpants, possibly in brown! Keep Posting, watching with bated breath. The 1009cc engine was rated at 28bhp with a total car weight of 762kgs. The GM 3pot on throttle bodies I reckon is about 70bhp but I'm aiming for a light body so about 500-600kgs?
scimjim
Club RR Member Number: 8
1947 Standard 8 hotrod scimjim
@scimjim
Club Retro Rides Member 8
Feb 28, 2014 15:09:57 GMT
a Rocket box would be hoooooogely over-specceed for that engine! A type E or type 3 would be more than enough (and a whole lot cheaper) - type 9 if you want the extra gear?
Feb 28, 2014 15:51:33 GMT
a Rocket box would be hoooooogely over-specceed for that engine! A type E or type 3 would be more than enough (and a whole lot cheaper) - type 9 if you want the extra gear? So these other boxes mount to a "type 9" style bellhousing? i just though the 'rocket box' was the name of the ford standard 4 speed'er before the type 9 came along
scimjim
@scimjim
Feb 28, 2014 16:41:09 GMT
The Rocket box is a type E with close ratio gears.
Don't know anything about the GM motor but you can get bellhousings for the type E, 3 & 9 for the CVH which shares bolt pattern with a wide range of 4 pot fords.
marinacoupe
Feb 28, 2014 18:39:53 GMT
Why not go old school? Standard Triumph Spitfire/Herald 1200 or 1300 engine and gearbox could be the most appropriate or BMC A series from MG Midget. Both can be fitted with fuel injection and mapped ignition to improve reliability and running costs. If you can prove original year of manufacture it'll be tax and MOT free, unless you get pinged for upgrade/changes as a radically altered vehicle, then it could need SVA. www.gov.uk/vehicle-registration/radically-altered-vehicles
Feb 28, 2014 18:43:46 GMT
Dirt cheap 12k mile Fiat lump here if you stuck - mega cheap!
Paul
Feb 28, 2014 19:09:58 GMT
The Rocket box is a type E with close ratio gears. Don't know anything about the GM motor but you can get bellhousings for the type E, 3 & 9 for the CVH which shares bolt pattern with a wide range of 4 pot fords. excelle3nt...i'll look out for one of these boxes. they'll mount up to any of the later GM lumps they all use the same bellhousing pattern and I can get a bellhousing adptor off the shelf
scimjim
@scimjim
Feb 28, 2014 19:31:47 GMT
just checked and the Type 3 gearbox has a 7/8" 20 spline input shaft, whereas the Type E and Type 9 have a 1" 23 spline input shaft.
I have a spare type 3 (with CVH bellhousing if required)
sonus
Feb 28, 2014 19:52:03 GMT
Looking forward to this build. I've got two Standard Eight frames. My father is building another 8 tourer for hill climbing none the less. He's using a Mayflower engine. I'm think about making a special with a blown Mayflower motor out of one of my parts bin. Just imagine tearing up the hill with a 1000cc 50bhp blown side valve ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Feb 28, 2014 19:52:42 GMT
just checked and the Type 3 gearbox has a 7/8" 20 spline input shaft, whereas the Type E and Type 9 have a 1" 23 spline input shaft. I have a spare type 3 (with CVH bellhousing if required) I'll need to do some research on clutches as I suspect the 1" 23 spline shafts are well catered for.
Feb 28, 2014 19:55:49 GMT
Why not go old school? Standard Triumph Spitfire/Herald 1200 or 1300 engine and gearbox could be the most appropriate or BMC A series from MG Midget. Both can be fitted with fuel injection and mapped ignition to improve reliability and running costs. If you can prove original year of manufacture it'll be tax and MOT free, unless you get pinged for upgrade/changes as a radically altered vehicle, then it could need SVA. www.gov.uk/vehicle-registration/radically-altered-vehiclesI have the buff logbook and the v5 logbook for the car - it has an unaltered chassis, both axles, front/rear suspension and the steering system so well over the 8 point threshold.....
Carter
Feb 28, 2014 20:00:37 GMT
Going to be a great project, nice one!
'77 Chevy G20
Feb 28, 2014 20:58:36 GMT
Great project if the cable brakes on my Austin 7 are anything to go by, you're better off carrying an anchor and chain in the car and throwing it at a tree when you need to stop!
Last Edit: Feb 28, 2014 21:01:26 GMT by bmwv8capri
marinacoupe
Feb 28, 2014 21:03:12 GMT
This will be fun, bookmarked it for the full story to develop.
