Jan 25, 2014 16:51:39 GMT
I want to use my Marlin for gentle green laning. Suspension can easily be raised as it's lowered from the donor Marina settings anyway so removal of the lowering blocks and turning up the torsion bars sorts that. Wheels on the other hand can be a problem due to the 3.75" PCD however that is the same as the MGF so adapters to 4 x 100mm are available. So can anyone suggest a 15" wheel with 100mm PCD that is narrow enough to take something like 155 or 165 profile tyre ?
Cheers.
Paul H
sal
Mk2 Cavalier CD
Jan 25, 2014 17:04:24 GMT
I think that vauxhall are 4x100 pcd if that's of any use to you.
Just had look on eBay and they are 185 or 195's. only thing small enough are space savers which isn't the best solution.
Last Edit: Jan 25, 2014 17:07:44 GMT by sal
Jan 25, 2014 17:40:15 GMT
I'll probably have to look at 14" as well because that will give far better choice. So revised question is the same as before but 14"
Jan 25, 2014 18:01:33 GMT
MGF and TF have a 5.5J x 14 steel spare wheel with 175/65 R14 tyre, but I guess you could put something like a 155R14 M+S tyre on them.
Click picture for more
Jan 25, 2014 18:09:20 GMT
Go for 14s I no a few people that do car trailing and they use the 175 14 vredestiens.good nobbly tyre and good ground clearance
Jan 25, 2014 18:49:04 GMT
mx5 steel wheels are quite narrow and 4x100 pcd as are some golf's polo's etc
1965 Morris Minor 1000 soon to be 1380 1997 MK1 MX-5 1.8 (sold) 2009 MK3 MX-5 2.0 (sold) 2008 Mini Cooper (sold) 2003 Mini Cooper S (sold) Fixed wheel Raleigh Clubman (sold) 1982 Yamaha RS125DX (sold)
Jan 25, 2014 19:25:00 GMT
Mini One steel wheels are I think a 5.5" width. I have a brand new set of black ones if you're interested.
Longstone classics list 165 profile radials for 15" rim. There are also some gravel spec rally tyres in 175/70 15
MrSpeedy
East Midlands
www.vintagediesels.co.uk
Sounds to me like you want to be looking for space savers
craig1010cc
Club RR Member Number: 35
Jan 29, 2014 18:06:20 GMT
MX5 ones are 5.5x14's and not the easiest to source. Any idea what offset you're going to be looking for?
Jan 29, 2014 18:19:51 GMT
you can rule Vaux 15 inch steels they are 6.5 j some re 6 j but harder to find, best bet as mentioned spacesavers
markbognor
Club RR Member Number: 56
Jan 29, 2014 20:04:20 GMT
Later K11 Micras had a 14" steel, 5 or 5.5 and nice high offset to cope with the spacers.
Jan 29, 2014 22:26:13 GMT
vauhall/renault?
E36 328 Touring
Jan 29, 2014 22:55:31 GMT
Toyota IQ steels are 15x5j, ET45 and 4x100. Not many kicking about second hand though, maybe in salvage yards. Ebay linkEdit... I'm half tempted to get a set for the MX5, I think 155s will be much more fun than 195s
Last Edit: Jan 29, 2014 22:58:27 GMT by SamR380
I've got Rovers.
