Question....... Some of those cars have solid rear axles (i think).....How do you get -ve camber on cars with solid rear axles? I know for golfs and some others you can get plates like wedges that give the stub axle neggy camber. RWD live axles I reckon would be done like nascar racers. cut and angle the tubes, then bevel out the internal splines on the sun gear/spool/lsd, allowing the halfshaft to run at an angle compared to the diff unit
whilst the photbucket is open
Question....... Some of those cars have solid rear axles (i think).....How do you get -ve camber on cars with solid rear axles? I know for golfs and some others you can get plates like wedges that give the stub axle neggy camber. RWD live axles I reckon would be done like nascar racers. cut and angle the tubes, then bevel out the internal splines on the sun gear/spool/lsd, allowing the halfshaft to run at an angle compared to the diff unit As well as that I found some info a few years ago about some live axles with hubs converted to run a cv joint on the end to allow camber and another forum (I think it was an AE86 one) where they had been heating one side of the axle case cherry red and cooling it to get it to warp and supposedly get a couple of degree camber each side Life expectancy wasnt too good on bearings and shafts
this is the best pic i have for showing the camber on the back. which it doesnt do very well, i might add.
I know for golfs and some others you can get plates like wedges that give the stub axle neggy camber. RWD live axles I reckon would be done like nascar racers. cut and angle the tubes, then bevel out the internal splines on the sun gear/spool/lsd, allowing the halfshaft to run at an angle compared to the diff unit As well as that I found some info a few years ago about some live axles with hubs converted to run a cv joint on the end to allow camber and another forum (I think it was an AE86 one) where they had been heating one side of the axle case cherry red and cooling it to get it to warp and supposedly get a couple of degree camber each side Life expectancy wasnt too good on bearings and shafts Interesting
rob0r
East of England
Club RR Member Number: 104
negative pic threadrob0r
@rob0r
Club Retro Rides Member 104
Shameless plug of some mild camber.
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
i wear tyres out in under 500 miles and you cant even see my negative camber although i have got a whole heap of toe in too, and i think a bent tie rod end ;D ;D anyways.
Dez
Club RR Member Number: 34
negative pic threadDez
@dez
Club Retro Rides Member 34
koppak
Just a touch ;D
that trabbi! ae86 camber adjustment! and low benz's like TCC's and dez's kick ass
healthy ammount considering its an I beam axle.
I have a negative sketch of my estelle worth showing - not only neg camber, but neg colouration! woohoo! [edit: it is, in fact, my current avatar ]
Negative camber on Live axles is easy enough 1 degree neg across the axle works really well and a little toe in doesnt hurt either ;D Theres enough tolerance in the splines and bearings to make no real difference Its an old Racing tweak thats very difficult to spot but when you set the car up to take advantage of it, it makes a big difference ;D
theres a distinct lack of imps on this thread, though imps invented it, they love their -ve camber
Last Edit: Apr 4, 2007 14:19:13 GMT by HoTWire
