ade36
I've had plans on building a Classic Scalextric Austin Metro for a while now. I started with a 3d chassis which was designed for the 6R4 variant. This chassis is intended to drop the body of the 6r4 quite dramatically; but in doing so, you have to cut out large sections of the body/arches, which you then cover up by relocating the 6r4 arch extensions higher up. I wanted to keep the narrow Austin body stock but still drop it down to a more realistic height... Cue the butchery! Untitled This gives an idea of where the chassis actually wants to sit Untitled Entertaining, but not what I'm after... Some trimming of the interior was required to clear the rear wheels Untitled The guide mounting needed to be shortened (a lot) to get the guide to sit behind the front valance, and the front axle narrowed to get the wheels to tuck a little. Lots of spacing, trimming and adjusting later and I finish with this: Untitled Untitled If i'm being picky, the rear tyres are a little large, but are needed for chassis ground clearance, and I still need to paint the rear wheel inserts. But the car is awesome... It's super nippy, and handles really well now too. And if you're wondering what the difference is from the original scalextric version: Untitled
Jul 29, 2020 10:21:56 GMT
Hydro unit gone pop? That is quite dramatic, your end result looks just right. I did one of these kits a while back of a mini clubman. The kit came with arches but I made my own arches instead. I was quite happy with the result, looks good, goes well but could be better. I planned to do a TR7 one with the widest axles I could get but havnt got round to it. Ive seen that some proper Carlos Fandango wheels have recently been released, so that might just tip me over the edge.
Jul 29, 2020 15:16:42 GMT
Heres an example of the wheels I mentiones. Available in several colours and designs, I want me some. Very much so.
Jul 29, 2020 17:35:29 GMT
Hydro unit gone pop? That is quite dramatic, your end result looks just right. I did one of these kits a while back of a mini clubman. The kit came with arches but I made my own arches instead. I was quite happy with the result, looks good, goes well but could be better. I planned to do a TR7 one with the widest axles I could get but havnt got round to it. Ive seen that some proper Carlos Fandango wheels have recently been released, so that might just tip me over the edge. In the real world that would be air cooled and have a Beetle floor pan. Make a very cool cruiser.
chamba
I've had plans on building a Classic Scalextric Austin Metro for a while now. I started with a 3d chassis which was designed for the 6R4 variant. This chassis is intended to drop the body of the 6r4 quite dramatically; but in doing so, you have to cut out large sections of the body/arches, which you then cover up by relocating the 6r4 arch extensions higher up. I wanted to keep the narrow Austin body stock but still drop it down to a more realistic height... Cue the butchery! Untitled This gives an idea of where the chassis actually wants to sit Untitled Entertaining, but not what I'm after... Some trimming of the interior was required to clear the rear wheels Untitled The guide mounting needed to be shortened (a lot) to get the guide to sit behind the front valance, and the front axle narrowed to get the wheels to tuck a little. Lots of spacing, trimming and adjusting later and I finish with this: Untitled Untitled If i'm being picky, the rear tyres are a little large, but are needed for chassis ground clearance, and I still need to paint the rear wheel inserts. But the car is awesome... It's super nippy, and handles really well now too. And if you're wondering what the difference is from the original scalextric version: Untitled This is awesome! Always wanted to do the same with the Metro, but was thinking a cut and shut job on the existing chassis. Where did you find this one?
This arrived at the weekend. First car from MSC. Looks good and goes well.
Aug 18, 2020 17:45:46 GMT
Just don't seem to be able to say no a new Pioneer car (or two).
Aug 24, 2020 18:32:44 GMT
Really must stop email updates of new cars from Scalextric. Latest VW van from them.
Last Edit: Aug 24, 2020 18:33:05 GMT by disastra98
Aug 27, 2020 19:01:04 GMT
Stumbled across this on Youtube and it sent me off buying Toranas. Two arrived today with another on its way. The two door fastback version will be out later this year to. Lots of races to watch from a good few years.
ade36
Aug 28, 2020 17:45:39 GMT
Stumbled across this on Youtube and it sent me off buying Toranas. Two arrived today with another on its way. The two door fastback version will be out later this year to. Lots of races to watch from a good few years. Nice, I’ve got the Kubota livery Torana (and an XC Falcon to go with it). Cool car, but I run all mine magless, and the skinny FF motor is a bit of a handful. Considering sticking a js chassis on it so I can run a mab motor
Aug 29, 2020 11:05:39 GMT
Another Torana added to the collection. Ade36, I put the magnets back in mine because they are such a handful without them in.
ade36
Sept 7, 2020 18:48:59 GMT
Another Torana added to the collection. Ade36, I put the magnets back in mine because they are such a handful without them in. Went to put the magnet back in mine, and the clip which holds the magnet in snapped in the process. Oh well, guess mine’s staying magless!
Sept 8, 2020 18:45:39 GMT
I spent a bit of time over lockdown converting my roof space into a useable man cave. Ive wall mounted my TV and put my racing sim in but i also had ample space to get my scalextric out. I will expand on this track as i go but its a great starting point. Very nice man cave. Had mine in the loft at first, to cold in the winter and so hot in the summer it warped the track. You also look to have much more head room than I have roof slopes on three sides.
Is Scalextrics dead?slipngripross
@slipngripross
Club Retro Rides Member 149
Yea i can stand up no problem which is great. I'm having a Velux fitted soon and we have 5 dyson fans in the house so one of them keeps me cool or warm weather depending
ade36
Sept 11, 2020 8:58:54 GMT
Sept 12, 2020 18:06:42 GMT
Latest Camaros from Pioneer. First street versions they have done. The blue metallic really is superb photo doesn't show it to well. ade36, So sorry but you know it made sense to have a pair to race.
Sept 15, 2020 17:40:26 GMT
Nice use of the joist.
Sept 29, 2020 19:13:14 GMT
Postie dropped these two off today. Cougar and another Torana.
