Aug 13, 2013 14:45:31 GMT
I've got a Volvo 760 with the D24Tic engine (2.4 6-cyl IDI turbo diesel) running more boost (16psi - standard T3) and more fuel.
The exhaust rotted away and has broken at the first joint, so now is the time to fit something proper.
I was thinking 2.5" stainless from turbo back, then one cherry bomb silencer (3" width/18" long) at the rear. My mate runs a garage and says he can build the exhaust if I buy all the bits.
Does 2.5" sound about right for the spec? Think standard is 2". Want something that sounds nice, but not "too" loud and want something that helps the turbo spool a bit quicker.
What wall thickness should I go for? 1.5mm/2mm? It will be T304 stainless. And, does anyone know anywhere in the West Midlands I can get a few mtrs for a good price? I was going to go to MIJ exhausts which is about £14/mtr for T304 2.5", but after I did a search and found lots of problems with their "stainless" pipework rusting I'm a bit put off...
1994 Mini Mayfair MegaJolted with BMW M3 seats; 1990 Volvo 760 D24Tic 16psi, more fuel, running SVO/WVO; 1965 Triumph 2000 Mk1 projects.. one day;
Aug 13, 2013 18:59:26 GMT
2.5" size is fine the whole way through - no need for the 3" backbox (unless you're getting it cheap of course!) don't forget, you don't need the CAT either, so that can be weighed in if you've still got it
Actually slight change of plan - for the sake of being cheaper and quicker, I'm keeping the original downpipe from turbo - which is 2.25". I'll change that to 2.5/3" if/when I stick a different turbo on! So just going 2.5" from downpipe, all the way to the rear, where I'll have the one cherry bomb and tailpipe. Just to clear up - the cherry bomb is 2.5" input/output, but the physical can size is 3" wide. I got it wrong though, it's 12" length not 18" - will that be ok? www.ebay.co.uk/itm/160542830387?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649Oh, and for some reason my Volvo had no Cat or EGR from factory.
Last Edit: Aug 15, 2013 8:11:44 GMT by ian2000t
Colonelk
Club RR Member Number: 83
as chairchild says, you *may* find it too quiet with the backbox, so a bit of experimentation may be in order
Aug 15, 2013 10:02:48 GMT
Lol, so you reckon no silencer at all?
Last Edit: Aug 15, 2013 10:03:10 GMT by ian2000t
Philj
Aug 15, 2013 10:55:13 GMT
Not unless you want it to sound like a skeleton having a rodpull in the cupboard. I'd go bigger than the box on ebay personally.
Last Edit: Aug 15, 2013 10:55:39 GMT by Philj
Colonelk
Aug 15, 2013 11:12:33 GMT
different strokes for different folks!
Aug 15, 2013 11:33:15 GMT
Not unless you want it to sound like a skeleton having a rodpull in the cupboard. I'd go bigger than the box on ebay personally. Woah... what now?? Well, one says no silencer, one says bigger silencer, so I'm in the middle - which is kind of what I wanted - not too loud, but with a nice growl! The silencer will be at the end so even if it's too small, it wouldn't be the end of the world to swap it out.
bortaf
Aug 15, 2013 13:25:12 GMT
The turbo takes out a lot of the noise of the combustion, a LOT When the rear section fell off my lucida TD i didn't even notice, which was a PITA cos when i spent £200 replacing it it made it no quieter at all, i should of just put a side exit on the broken end and left it, the box that did stay on was smaller than that ebay one but wasn't a straight through like the cherry bomb which to be honist is more like a straight tube with a bulge on it LoL
R.I.P photobucket
Aug 15, 2013 13:30:43 GMT
Cool, I'll give it a go then! Will post a vid when it's done, but probably won't be for a few weeks.
Aug 16, 2013 21:41:59 GMT
I actually meant, don't bother with a 3" backbox, as a 2.5" is usually quite a bit cheaper :lol: I've used a midbox off a citroen XM as a backbox before, sounded quite nice. Straight-through as standard too.
A derv with no backbox sounds nasty...
Aug 19, 2013 12:13:46 GMT
Right ok! Well, I picked up 3m of 2.5 stainless tube, and a Jetex 2.5" stainless over axle bend the weekend.
Just need to order the silencer and possibly a tail piece. Do you think a 12" long 2.5" cherry bomb will sound ok - not "too" loud, or nasty like it has no backbox?
Copey
Aug 19, 2013 13:47:45 GMT
stick a cherry bomb back box on the back
Aug 19, 2013 17:56:09 GMT
I'd look up what the non turbo variants used, i know on a 405 they used the same bore pipe but no centre silencer, as they had a resonator on the manifold instead, the turbo had centrebox and a large rear box! Mum's 405 TD now runs turbo rear box only You could go all scientific and work out gas speeds and where to taper the exhaus from turbo elbow at say 2.5" down to 2" at the rear, i know a 170 bhp pug petrol runs exactly that, revs to 7450 (peak at 6500) and the 200 bhp 200 lbft 6000 rpm 3.0 v6 is 2.75 tapering to 2".
