Copey
Jul 15, 2013 17:54:32 GMT
went to go out in the saph this evening and it wont start, sounds like the ticking is coming from the Foxguard immobiliser, or possibly a relay behind the dashboard? not sure which but its not priming the fuel pump or even trying to turn the starter motor, so i would wager its the Foxguard, anybody had this happen before?
is a 2.0 I4 injection engine if that helps
cheers for any help
IDY
Jul 15, 2013 18:09:12 GMT
Checked the impact fuel cut off switch? not sure where it is on the saph
I will get round to finishing it at some point
Copey
Jul 15, 2013 18:12:19 GMT
yeah in the boot under the spare wheel, not that sadly, has caught me out before when i had a flat tyre and knocked it hehe
IDY
Jul 15, 2013 18:16:41 GMT
Just dug out my Ford Sierra Owners Handbook 1987 6th edition it claims that it is in the spare wheel well on all models the cut off was fitted to. It is possible to set them off by dropping the spare wheel back into the well Thinking about it I don't think it will be this as you said its not even trying to turn the engine over edit - too slow lol
Last Edit: Jul 15, 2013 18:19:27 GMT by IDY
Copey
Jul 15, 2013 18:21:17 GMT
haha, thanks anyway mate n aye, it normally does try n turn the engine over, just cuts the fuel pump off i think
IDY
Jul 15, 2013 18:26:05 GMT
According to my handbook relay 1 in the main fuse box is for the ignition switch, worth a check?
Copey
Jul 15, 2013 18:26:48 GMT
will give it a look, thanks
Copey
Jul 15, 2013 19:02:29 GMT
decided to pull the dash apart and it was the immobiliser box that was clicking, dodgy connection, so all sorted now
bortaf
Jul 15, 2013 19:06:02 GMT
Have you checked the starter conections ? although if it was that the pump would still prime when the ign was first turned on and yes the starter would still turn if the fuel shut off had tripped, laters cars it's in the driver kick panel not the boot
R.I.P photobucket
Copey
Jul 15, 2013 19:13:29 GMT
its sorted now cheers though Bortaf
