Hi,
I have a car whose PCD is 4x108, but I just bought these gorgeous wheels that are 4x100. Frustrating.
Now, I've heard that Giulias don't like anything wider than 6" (they're on the limit), and offset under 35 (I have no idea at all about that). They are BWA 119, 6JJx14H2 I believe.
I'm not too worried about the clearance issues, because this seems to come from people who want to run the largest possible tyres, which I couldn't care less about. PCD adapters cost an arm and a leg, even second-hand, but sometimes you can find solid spacers. Is it possible to re-drill these to turn them into adapters?
www.leboncoin.fr/equipement_auto/499948457.htm?ca=3_s
They are 16mm thick, if that's any importance. I found these as well:
www.leboncoin.fr/equipement_auto/497347776.htm?ca=3_s
What should I look for, to make sure they can be re-drilled? Is 16mm thick enough?
Thanks!
Thanks!
