munky
Covins are quite rare over here (US) but wish I had one rather than my 912s which were both riddled with metal worm (one worse than the other). Then this turned up just over the boarder in Canada - two untouched bodies. One slope nose convertible, the other wide bodied coupe! www.usedvictoria.com/classified-ad/kit-cars-covin-kits_25889076Sweet car. Keep up the great work!
Last Edit: May 13, 2016 0:38:11 GMT by munky
Covins are quite rare over here (US) but wish I had one rather than my 912s which were both riddled with metal worm (one worse than the other). Then this turned up just over the boarder in Canada - two untouched bodies. One slope nose convertible, the other wide bodied coupe! www.usedvictoria.com/classified-ad/kit-cars-covin-kits_25889076Sweet car. Keep up the great work! That's close enough for me! I've been looking for awhile!
Saw this, and thought of you... Apologies for terrible link but iPad isn't really forum friendly.... EDIT: it worked a lot better than I thought it would, great save. Great video...nice to see some 914's in there as well
luckygti
I need to try harder!
Oh God! My level of wanting a 912/911 just went up about ten notches after watching that love this car, and when I get space in the workshop/finish building the house, there's a Porsche gap that needs filling!!
nel5on
West Midlands
May 18, 2016 19:32:15 GMT
Covin 996.2 Tucson
May 18, 2016 20:52:12 GMT
I keep coming back to this every couple of months to have a read through your work. Well done on getting an MOT! It looks nuts! I concur with others about a drive video being needed
May 18, 2016 22:14:17 GMT
Listed in the bumpers and rubbing strips category? ?. Weird ha ha
May 19, 2016 11:44:34 GMT
Mark
May 26, 2016 14:02:37 GMT
Haven't logged in for a while so seeing this is on the road was a pleasant surprise. It looks freakin' awesome and certainly has a far higher cool rating than when you started. Easily well over 1000 megafonzies!
E36 BMW 318is saloon (rare as a hens false tooth) VW Caddy Maxi 2010 (usually full of Labradors)
May 28, 2016 13:42:19 GMT
I keep coming back to this build for inspiration and to check in and see how you are doing with it.
JP
May 28, 2016 18:10:49 GMT
Nice build
Caravans are cool
May 29, 2016 16:44:51 GMT
Back seat practically there. Just waiting for lap belts to arrive. Not happy with the finish on the side panels, so they will be redone at some point.
mattiwagon
Just got a work truck
May 29, 2016 23:36:09 GMT
Are they 924 seats upside down?
If they cant be nice f**k em!
84 low t25 panel 1.9td beige and rust combo 97 Goped Bigfoot G260RC with clutch conversion 97 Impreza turbo 2000 builders wagon 76k sold 04 Fabia vRs 50mpg pocket rocket 04 battered T5 pickup in blue! Chainsaws lotsa Chainsaws
Darkspeed
Club RR Member Number: 39
1967 Covin Nein12Darkspeed
@darkspeed
Club Retro Rides Member 39
May 31, 2016 11:04:59 GMT
Also worth noting when messing about with these types of wiper systems that the wiper wheel boxes are also available in different sweeps as well as pinion depths. Typically the passenger side getting a 135 degree sweep and the drivers 90 degree - Been in quite a few cars where this has has been ignored either having wipers clean off the screen on the drivers side or leaving unwiped centre sections.
wodge
May 31, 2016 11:07:03 GMT
Its this level of attention to detail which makes me love your threads. Love how this is turning out, only thing I'm not totally sold on is the rear lights I think i'd be digging deep for some genuine Porsche items. Carry on sir!
May 31, 2016 11:51:19 GMT
Also worth noting when messing about with these types of wiper systems that the wiper wheel boxes are also available in different sweeps as well as pinion depths. Typically the passenger side getting a 135 degree sweep and the drivers 90 degree - Been in quite a few cars where this has has been ignored either having wipers clean off the screen on the drivers side or leaving unwiped centre sections. The wheel boxes are mostly likely 32 teeth (mini, mg triumph etc) items (just an assumption as those are the most common and cheapest, bought back in the early 90's with the unipart wiper motor. The common choices are 32 or 40 teeth boxes. you can get 22 teeth but are very early mini and other random cars and are rather expensive. So as Seth advises me, the lower the teeth number, the wider the arc. my next option will be look at the gear drive arm. i think a shorter arm gives a wider arc coupled to the 140deg cog. i believe the max cog size you can get for thb 14W motors is 150 degrees but are very rare.
May 31, 2016 12:31:26 GMT
simply brilliant work on the wiper system....I still struggle with "system comprehension".....though I may get how a component works, getting beyond that sometimes requires MUCH thought!....
well done!
JP
Covin spannering to resume shortly as i've been pre-occupied of late
