12" x 5" wheels with 165/60/12 tyres. No rubbing what so ever & fit the arches well. Handles sweet compared to the steels that were on there Forgot to add AA badge is an addition & also resprayed the front bumper to get rid of some rust... May do an electronic ignition upgrade on it too...
It was acceptable in the 80s!
12" x 5" wheels with 165/60/12 tyres. No rubbing what so ever & fit the arches well. Handles sweet compared to the steels that were on there Forgot to add AA badge is an addition & also resprayed the front bumper to get rid of some rust... May do an electronic ignition upgrade on it too... Cheers for that - Did you go for Yoko's, Falkens or something else? I have been looking at electronic ignition for mine - Probably going to junk the whole Ducellier distributor and replace it with an electronic Lucas unit. Goodbye to points!
1950 Ferguson TE A20 1971 VW Beetle 1300 1972 VW Beetle 1302S 1977 Leyland Mini 850 1983 Austin Metro 1.0 HLE 1984 Honda Acty TN 550 1989 Rover Mini 30 1990 Rover Mini City E 1990 Mazda MX5
apart from drain the fluid out which would cause a really bad ride...how can you lower a metro?
Fling a few, ermmmm 'chunky' people in the back...!!!!
***GARAGE CURRENTLY EMPTY***
Fling a few, ermmmm 'chunky' people in the back...!!!! I like the cut of your jib there
Jul 15, 2013 13:30:54 GMT
12" x 5" wheels with 165/60/12 tyres. No rubbing what so ever & fit the arches well. Handles sweet compared to the steels that were on there Forgot to add AA badge is an addition & also resprayed the front bumper to get rid of some rust... May do an electronic ignition upgrade on it too... Cheers for that - Did you go for Yoko's, Falkens or something else? I have been looking at electronic ignition for mine - Probably going to junk the whole Ducellier distributor and replace it with an electronic Lucas unit. Goodbye to points! Wheels came with Falkens, handles really well with them on. Yes - good ridens to points!
phil1380
East Midlands
Only the depth varies........
apart from drain the fluid out which would cause a really bad ride...how can you lower a metro? The same way you lower a mini. You have to take the aluminium trumpets out and shave some off the ball-joint end, then put it all back together again. I'm not sure what the ratio on a metro is, perhaps someone on MetroPower will. On a mini it's 3 to 1 on the front and 5 to 1 on the back, I think. The only ball-ache is you will have to de-pressurise the hydro to remove the trumpets, re-pressurise once you're done, then let it all settle out before you'll know how much effect you've had. If you've gone too low at least you can add a spacer washer under the ball joint like Rover did for the Sportpack Mini's to raise it back up again. Phil.
Jul 16, 2013 16:12:23 GMT
apart from drain the fluid out which would cause a really bad ride...how can you lower a metro? The same way you lower a mini. You have to take the aluminium trumpets out and shave some off the ball-joint end, then put it all back together again. I'm not sure what the ratio on a metro is, perhaps someone on MetroPower will. On a mini it's 3 to 1 on the front and 5 to 1 on the back, I think. The only ball-ache is you will have to de-pressurise the hydro to remove the trumpets, re-pressurise once you're done, then let it all settle out before you'll know how much effect you've had. If you've gone too low at least you can add a spacer washer under the ball joint like Rover did for the Sportpack Mini's to raise it back up again. Phil. now theres a man that knows his stuff!!!!
