jimi
ivanhoewThe headlining diverts it to other random areas, T-bars are the same, a common leak is caused by the centre bar but it doesn't show there. Strangely enough it always seems to be the drivers seat that gets it š¤ Out of habit if I park mine up outside for any length of time the the T-bars fitted I always put the T-bar bags on the seats with the vinyl side up .... just in case š
Black is not a colour ! .... Its the absence of colour![](https://jlawson.co.uk/images/Jimisig04.jpg)
jimi
The windscreen is bonded in, if its leaking at the top then its likely corrosion causing it, needs investigating or it can end up like this (if it isn't already) ![](https://i114.photobucket.com/albums/n266/coverco/100_0763-1.jpg)
I've investigated further. More later. But to join in on the chat... kevins , Gaffer tape is the current temporary solution. I'd like a more permanent temporary solution. Something that'll buy me a year or two. Or, knowing me, ten. jimi , Thanks for the Paul Woods link. That's roughly the plan but I have a shrinker so that'll make life easier. eurogranada , The major difference is that your car is an absolutely stunning piece of work and mine is a scrap yard that nobody would miss if it got killed off and buried under the patio. In fact the only reason I don't kill it off violently and bury its remains under the patio is that I can't be bothered to dig the patio up. Guess the car's getting fixed then... ivanhoew , Pretty much as Jimi said. The headlining is a moulded fibreboard with a cloth glued over it. I don't think this is a devastating leak, instead it slowly saturated the front edge of the headlining and eventually started running out on the right side of the car. Who knows why it chose that point. vulgalour , Thank you, I'll put that on the list when I work out what to do with it. The windscreen is bonded in, if its leaking at the top then its likely corrosion causing it, needs investigating or it can end up like this (if it isn't already) ![](https://i114.photobucket.com/albums/n266/coverco/100_0763-1.jpg) It's trying to look like that. And it's doing a reasonable job too.
Last Edit: Nov 6, 2023 19:29:38 GMT by Sweetpea
jimi
I'm sorry I was right ![:'(](//storage.proboards.com/forum/images/smiley/cry.png) would have been nice to be wrong on this occasion, unfortunately I've seen it before on more than 1 MK1. However given where you started and where you are now I'm sure you'll do a great job of dealing with it ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Better finding this now rather than when you have painted the rest of the car. The red car in the first picture belonged to Coverco (Tommy Ogle) this was it about the time he sold it in 2013 ( obviously after he restored it)
Last Edit: Nov 6, 2023 20:32:26 GMT by jimi
eurogranada
Thanks for the compliment sweetpea, much appreciated, but I think you're either over selling mine or under selling yours. And you know my car was once where your car is now as well so... And as others have said, you've already come so far!
Youāll have to forgive my lack of action over the last few weeks. Itās not that Iāve been doing other things. Iāve been doing nothing. I was in work a few weeks ago and came home with what turned out to be Covid. No great surprise. Itās the beginning of the flu season and sickness is running high at work. Anyway, Covid for me was just a nasty cold this time but it did knock my stamina and general motivation back a bit. Itās probably one reason Iām a bit down on the car. Ok, so letās investigate this leak. I want to confirm that it really is the windscreen aperture and I want to know how bad the problem is. You see, to fix this properly means taking the glass out and Iām not doing that coming into a stormy and unsettled winter. In fact I want to get the car back on the road so I can recover my relationship with it a bit. Ideally I want to stabilise whatever the problem is and buy myself a couple of years. The windscreen is bonded into the hole and some trim makes it look pretty. To get a look I need to remove the trim. The two side mouldings are an easy win. They are just screwed on. The upper moulding should be held in by a series of clips. However my car has had the windscreen replaced at some point and the clips frequently got damaged, lost, and broken so the trim is likely to be bonded to the car. If thatās the case then Iām in bother because itās not coming off without a fight. It turned out that the left side moulding was stuck to the windscreen adhesive. In fact the adhesive seems to be better stuck to the moulding than to the glass. Really??? Yes, really. When the new windscreen was fitted the chap must have put the glue on the glass rather than on the car. He must have run the bead down the very edge of the glass. Now thatās a problem because the glass is wider than the structure of the car and he got it on 6 or 7 mm offset to the left side. That meant that the adhesive on the left side only got a passing contact with the car and didnāt stick properly. Iām fairly sure if I gave that a pull itād come out for the whole left side of the glass. Should make it easier to get the glass out without breaking it though. For the record, as well as getting the glass offset to the left of the car itās also slightly rotated anticlockwise so itās low on the drivers side. I mean itās not terrible but it was clearly done with a greater emphasis on speed than finesse. Predictably the top trim was glued in and was a right pain in the biscuits to get off. I think Iāve got it out without mangling it too much. Iām not sure I could get a good replacement. Underneath the channel was completely filled with glue. I thought wheyād have spot glued it in but, nope. The windscreen chap didnāt want this trim coming off again. Ever. The goo got cut and ripped out so I could see the increasing entropy hidden beneath. Well it doesnāt look great. And, yes, there is a hole. No great surprise as itās right by a rust blaster on the roof. I tidied up the visible part of it a while back. Partly to make it look a little better but also to hold back the damage. Too late I guess. The hole is about an inch and a quarter long now Iāve poked it a bit. When Iād finished poking it I stuck some gaffer tape over it and went inside for a little weep. So whatās the plan? Well the first thing is to think of some sort of planā¦ Iām going to spend some time properly cleaning it all out. Then, assuming itās not completely spanked across the whole width of the car, I can get a load of Hydrate 80 on it to hold back the rust. And then some epoxy primer to keep the water off it. That should stabilise things. Then Iām wondering about fibreglass to bridge the holeā¦ Dunno. Depends on how bad it all is when I clean it up. James
jimi
Gaffer tape is the current temporary solution. I'd like a more permanent temporary solution. Something that'll buy me a year or two. Or, knowing me, ten. James One of the PT Cruisers I had developed a similar leak, didn't drip anywhere, but I used to end up wet carpets in the drivers footwell, took a while to find out it was coming from the top of the windscreen. I had the screen replaced (no choice, it was bonded in and broke on removal) 4 months later the leak was back. I ended up putting a strip of black 1" electrical insulating tape across the top of the windscreen trim, overlapping onto the roof. That stopped the leak, because the trim was black (very similar setup to the MR2) you couldn't see it unless you were looking for, it was still there (and working) 4/5 years later when I traded the car in. Might work for you as a longer term temporary measure ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) ![](https://jlawson.co.uk/originalsite/May_06/slides/may06_17.JPG)
jimi
Must have overlapped your last post, a bit to late for the above now ![:-[](//storage.proboards.com/forum/images/smiley/embarrassed.png) Liked your last post for sympathy !
Last Edit: Nov 8, 2023 21:08:24 GMT by jimi
jimi
BTW I have 2 good windscreen side trims specifically for a moonroof. I bought them years ago for mine only to find out the T-bar trims are different š¤¦āāļø Yours if you want them ? Free on my usual terms (donation to the RNLI to cover the postage)
The British Isles are a difficult place for cars. The sight of that wet rusty gully and the hole is tough to behold.
John
eurogranada
I feel for you. Difficult choice to face at this point...
Does the discovery of the badly bonded in screen sway your opinion on going for a medium term temporary fix in any way?
funnily enough my astra had a 2mm wide gap down the near side window edge ,and hence had filled the floor with water and shorted out the electrics under the carpet , hence cheap car .
its a real dilemma isn't it , clean ,and fibreglass and fill , or take out screen and weld in a solid bit. .
it's a difficult one, If you had somewhere under cover I would say bite the bullet get the screen out fix it and never worry about it again, once the screen is out it won't be that big a job, and being a T bar you should be able to get away with just painting the header. (a pro rattle car would do that easily).
anther option which might buy you some time would be to trim back as much of the rust as you can treat/paint it all glue a patch over the hole with PU and stick the trim back on. I did a "temporary" repair on the inner wing of my Range rover like this 3 years ago, its still fine.
My vote is:winterproof it and fix properly in the spring, it will niggle away in the back of your mind if you ābodgeāā it now š
Last Edit: Nov 9, 2023 15:45:59 GMT by westbay
jamesd1972
Club RR Member Number: 40
James.
jimi
My tuppence worth : I only have to think back to the front bumper to know you will sort it properly, given that, I wouldn't do anything that isn't easily undone but make it watertight for the winter. In the better ? weather get the screen removed and do a proper job of repairing it š If it was mine that would be my plan š
Last Edit: Nov 9, 2023 19:28:27 GMT by jimi
Thanks for the thoughts and support folks. I was going to answer individually but Iāll just tell you all what Iām thinking in a moment. A couple of messages first thoughā¦ Whatever you do, don't poke it! Oops, I poked it! jimi , Thanks for the offer of the side trims. I think mine are ok apart from needing paint. (Iāve not looked closely yet.) Iāll let you know if I do need them. The British Isles are a difficult place for cars. The sight of that wet rusty gully and the hole is tough to behold. John I watch a couple of PooTube channels form US mechanics in the rust belt. We donāt do so bad! James. ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) Donāt tempt me. In truth I couldnāt do that. The can of petrol is worth more than the car. Letās take stock of things. A leaking windscreen isnāt going to fail the MOT. Being bonded in means itās a semi structural part of the car so itās not ideal that itās not properly glued down the left side but thatās not changed in a couple of decades. However this might fail the MOT one dayā¦ Itās rust in the bottom of the A pillar. I believe that itās just in the outer skin and there is a load of thick steel forming the structure behind it. Not hard to fix but it means taking the wings and doors off. I donāt want to take the wings off because they look like thisā¦ And I want to get some structure and shape back in there before I disturb them. The other thing that might fail the MOT is the suspension. There is one damper that started to weep. Again, swapping dampers isnāt a big job but Iāll want to refurbish everything and polybush it while Iām doing the job. So there are a couple of jobs that take priority over a leaking windscreen. Actually more than a couple because I also need to make some architraves for the hall and finish decorating it. Mrs Sweetpea has been very tolerant of my waisting time on the car this year so I really need to get the hall finished. The problem here is that when I say āmakeā the architrave I mean purchase some rough cut oak, run it through the thicknesser a few times, and then though the spindle moulder. That means I need space to get the machines out. Space that is currently taken up with bumpers, trim and a fuel tank that needs painting before it can go back on the car. Pratting about with the windscreen aināt a thing that my diary can cope with at the moment. Repairing it properly certainly isnāt happening. Another wee problem is that the weather looks like this a lot of the time. Rainy, wet and miserable. Itās not the time of year to be taking the windscreen out for a few weeks. Oh, itās a sunroof car and the paint on the roof and C pillars needs doing anyway. When I do this itās getting the full monty and, knowing me, thatās not going to be quick. This weekend (if the weather is passable) Iām going to get the stiff wire brushy thingy in the drill and carefully clean the channel out. Then weāll think again and see if everything I just wrote still stands. If itās so bad that the windscreen comes adrift and slides down the bonnet I might have to reconsider. I knew from the day I bought the car that Iād have to take the screen out and do the aperture. Thereās always been a blister on the roof. But I really could have done without this problem just now. If anybody tells you itās really cool to own a classic car, tell āem from me to f&@$ right off! Okā¦ Sometimes it is really really cool, and sometimes itās utterly infuriating. Again, thanks for the thoughts and support.
This is a realy nice project! I've rebuild a couple of 4AGE's 3 years ago.
jimi
jelmerv8Nice job on the engines š not UK (MAP) spec, look like AFM spec. USA or Canada ? š¤
Last Edit: Nov 9, 2023 22:07:53 GMT by jimi
jimi
Nov 10, 2023 12:01:18 GMT
jimi , Thanks for the offer of the side trims. I think mine are ok apart from needing paint. (Iāve not looked closely yet.) Iāll let you know if I do need them. No worries, they have been on the shelf in my garage for the last 10/15 years, probably still be there for the next 10/15 years ![(rofl)](//storage.proboards.com/forum/images/smiley/rofl.png) you know where they are if you need them
