I have a dream that one day this car will be back on the road.
‘Hopeless’ I hear you say. Well, we will see about that.
The engine hasn’t turned over since the fuel pump got stuck and that was ages ago. Years probably. Does it still turn over? Does it still have compression?
I stuck a ratchet on the crank pulley bolt and, yes it turns. I also counted four healthy compressions.
James breathes a sigh of relief.
All the oil will be in the sump so it’s a good time to change it and put a new filter on.
Once I had fresh oil installed I put the battery back on (freshly charged) and cranked the engine over to see if it’d build oil pressure.
Well, it wouldn’t crank. There was a clunk from the starter and all the dash lights went out. They didn’t come back on when I let go of the key either.
I tried a few times and it was the same story. So off I went to find my multimeter.
The plan was to flick it to start, have the power fail and leave it in that state while I went on a hunt. Except this time it cranked. Hmmm. I suspect I had a dirty relay that’s cleaned itself. I’ll have to keep an eye on that. I think I have some spare relays somewhere. Might be worth chucking one in the glovebox.
Anyway, engine cranked for a while and eventually the oil pressure started to come up.
I remember debating how best to store the fuel pump after I freed it up. In the event I chucked it in a plastic bag, lobbed it in a cardboard box and forgot about it. As it turned out this apparent negligence turned out to be a well thought out plan concocted by a world renowned genius. (Yes, I’m talking about me!) Also very handsome and modest, or so people say.
Where was I? Oh yes, the pump still worked so I assembled the tank and popped it by the car for fitting.
You know the rest. Ten minutes to get it in position and then a couple of days of bruised knuckles trying to get all the pipework connected. I think I used an entire years allocation of curses and will now have to live the life of a saint as a result.
Say goodbye to the date on the tank. It’ll be hidden for the foreseeable future. At least I really hope it will.
It was worth the week of effort to do that.
I’ve got a new Toyota fuel filter to go on (astronomically expensive from what I remember) but I’ll run the engine first just in case it sucks a load of crud out of the tank. I mean the tank is very clean looking and if it does suck up crud it’ll block the filter on the pump and the tank will have to come out again and you’ll see that date again…
Next we can reassemble the fuel cap door bits.
The springy thing, the latch, and all that plastic stuff round the neck got cleaned and fitted.
Yeah, I’ve used stainless cap screws to bolt it together. It won’t lose me any points at the concours car show because, by the time they’ve looked at the rest of the car there won’t be any points left to lose.
I have a small problem in that when the door is on the catch it’s a little proud.
It looks a lot worse in the photo than it does in person but it still needs tweaking. I can’t see how to adjust it though. Apart from just bending the frame of the door which might be how it’s done. Does anybody know?
The head light switch had been knocked on so when I connected the battery the pop up lights popped up. Well one of them did. The other got half way and got stuck. I had noticed that one light was getting lazy when I last drove the car. I guess the gear box needs cleaning and lubricating.
Ok… So here’s another thing I don’t understand.
That assembly looks like it should just unbolt from the car. Two bolts and two nuts in the front trunk and one bolt lower under the car. Then it should just come off the car. But it doesn’t.
The studs attached to the bracket need it to go directly forwards but the motor needs it to go forwards and down at about 45 degrees. It won’t do both so you have to take the motor off the bracket to get it off the car.
I don’t for a minute believe they built this up on the car when they built it but I can’t work out how they got it on the car in one piece. It don’t not make no sense it don’t not.
It wasn’t the gearbox. It was the hinge that the light swings up on that was rusted solid. You can’t disassemble it so I just had to lubricate and exercise it until it freed up.
It’s now quicker than the left side so I might have to do something with that one day. I’ve oiled it for the time being. Actually both lights need restoring before they rust away. But not tonight Josephine.
James
