Panda Matt, I know your first post was meant to be helpful (it was- very!) It didnt sound like you were complaining to me anyway.... I want to see it I want to see it!!!! Getting it on the weekend.... it could even be a sporting.. Probably a boggo standard 900cc one though. Ive found a sporting engine on egay but its just the block and head without any ancilleries, if the original engine is the 900 cc, will all the bits from that, starter, manifolds e.t.c fit the sporting lump?? Sorry for all the stupid questions. *edit* Oooh- would THIS fit? cgi.ebay.co.uk/Fiat-Punto-Sporting-engine-Mk-2_W0QQitemZ220083837157QQihZ012QQcategoryZ10382QQrdZ1QQcmdZViewItemI don't mind about bulging the bonnet ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
Last Edit: Feb 20, 2007 6:09:35 GMT by Lankytim
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Feb 20, 2007 10:37:05 GMT
I'm bloody tempted myself now after seeing this thread and the other one, what are they like reliability wise, as I'm pretty sure that fiat are supposed to be wibblepoo
Feb 20, 2007 10:45:42 GMT
Cinq or Micra are on my list ...loads of potential and loads of fun...
Feb 20, 2007 16:41:45 GMT
wibblepoo reliabilty as far as ive heard. The couple that own this cinq would have repaired it as apparently its a pretty easy job but this was "the last straw"
I'm guessing it had a history of unreliability.
RA40tony
Rollin' rollin' rollin'
Feb 20, 2007 16:54:46 GMT
Right,
Had a 1998 Sporting as a daily driver and it was amazing. Had some apex springs fitted and would curse word off a load of people in bigger machinery of the twisty roads. Picked it up in scotland and drove it back to Newcastle and drove it down to Luton a few times no prob.
I used to visit fiatforum regularly too. So anyway, if its a 900, you'll need a load of stuff to swap another engine into it (from memory subframe or xmember, gearbox, linkage, wiring loom for a sporting...) and better off using a donor sporting.
If its a sporting, the 1242 8v Punto engine will drop straight in (need to shave a bit of the plastic cam sproket cover and fit 10mm spacer between manifold and downpipe) and will run of standard Cinq sporting ECU. only 60bhp (against 55) but a HELL of a lot more torque.
1979 Toyota Celica GT. Currently Gone.
1975 Toyota Celica ST. 13x7 Allycats, "the stick" applied. 100kW 4AGE... Sold
1963 Karmann Ghia - Lo & Slo, Sold.
1965 VW Fastback - cruising
1953 Oval Ragtop, work in progress...
Darrel
Feb 20, 2007 19:12:17 GMT
Had a few. To be honest I wouldnt bother trying to tune the 899cc car. The gearbox's are run on cables and are very weak. They die normally anyway. Also if you go fast and hit a slight bend it can be quite scary. The second you try and tune it it will eat them. The Sporting is the much better option as it has far better handling with better suspension geometry, the gearbox is stronger and the Fire engine out of the UNO/Panda is very tuneable and quick if done properly.
Feb 20, 2007 21:56:47 GMT
We had one a few years back before a tw@t in an ML re-shaped it ! No competition big 4x4 verses ikle city car = R.I.P Cinqu ! When it had'nt been bent it was brilliant ! loved it so much that i would have another NOW.Lowered it on AVO's and it handled very well plus i topped the ton mark on a nice straight,top car,go for it and enjoy cheap motoring.
Just a modern....but surrounded every day by Porsche's !
Feb 20, 2007 22:23:28 GMT
2 obvious choices IMHO
Lancia Y10 Turbo engine
or
Punto 75 1242cc engine with multi point injection
Hummmm
I better hope its going to be a sporting, otherwise ill do the HG and bosh it on egay, or just bosh it on the bay as it is.
Darrel
well if its just a 899cc its an ohv engine and really easy to do. Get the headgasket done no matter what.
Either engine head gasket is easy to do ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) might make you back ache tho from bending down so far ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
