This is to adjust or maintain the door gap on triumph spitfires and heralds but will fit the majority of classic car door apertures. ideal when you are doing the sills on a soft top. the jaws clamp on to the flange where the rubber seal goes then you can pull or push the gap to the required size.
£55
£55
