stinkwheel
Doctor Of Gonzo Journalism - One of gods own proptypes, never even considered for mass production.
Guys you have overloaded me with info, thank you. i will bear it all in mind whilst i think about it and ley you know the plans.
I do not want to change to the fi hubs though as they have a different bolt pattern to the vans for wheels, dunno why.
1973 Citroen Dyane 6 1980 Citroen Acadiane 1992 Citroen AX 1990 Citroen BX 1997 Citroen XM 1993 Citroen BX 1997 Citroen Xantia 1977 Citroen Ami 8 1996 Ford Escort 1989 Citroen BX 1997 Suzuki RF900 1988 Yamaha TDR250 1979 Honda CB400. 'I need less vehicles'
rod
Just my 2p........(with disclaimer)......I have lowered many cars by cutting the springs ..to keep them captive use heavy stiff wire (coat hanger wire )to wire them into the cups . Have been thro' lots of mot's with them no probs at all , but may have just been lucky........You must reheat the end of the spring to flatten it to the next coil to provide a more or less flat seat,then grind it into a tang . Wouldnt be able to do pig tail type tho' !!! I personally would only ever do my own cars ,lots of people have asked me ,but I refuse . BTW Regard the spring material as a straight bar ,the shorter it is cut the more leverage is reqd to bend it ,hence the wound 'rod' gets stiffer by cutting coils .
Matt - you might find more info here : www.triple-m.co.uk/phpBB/index.phpDon't all rush for a look as it gets a little slow at times! (Shouldn't have said that should I? Now you are all curious!)
stinkwheel
Ta mr wobbler, already a member and look under the posting, lowering a maestro van in the modifications section, to be honest i got a lot more sense here
Had just noticed that the Triple M forum seems to have a "Readers Wives" section - a little odd!
