Back from holiday and pushed on with some more Aluminium panelling........They are only cut and bent to assess fit so will need adjusting then fixing in place. I did this then this and this finishing with this....
May 23, 2016 16:07:27 GMT
Not forgotten! But not much progress - the other rear wheel has been refurbed and fitted.
I have been on E Bay recently, as I had cracked the windscreen against the roll cage sometime ago, anyway, I have now got a good screen as a replacement. Then I looked for a pair of seats and after a trip out today I have got these. So slow progress is being maintained....
Frankenhealey
Club RR Member Number: 15
Pro Jag "MeGa B" GT V12Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Phil, Your RodsnSods picture hosting does not seem to be working so we can't see the great progress Cheers, Ian
Phil, Your RodsnSods picture hosting does not seem to be working so we can't see the great progress Cheers, Ian Sorry Ian but there is an "Issue" with RnS image hosting which the "techies" are looking into.....
Hopefully pictures now showing???
mattiwagon
Just got a work truck
Yep! Awesome build
If they cant be nice f**k em!
84 low t25 panel 1.9td beige and rust combo 97 Goped Bigfoot G260RC with clutch conversion 97 Impreza turbo 2000 builders wagon 76k sold 04 Fabia vRs 50mpg pocket rocket 04 battered T5 pickup in blue! Chainsaws lotsa Chainsaws
I have tried the seats in the B - and they appear to be Big - or is it the BGT is Small!! Anyway I have also been tweaking on the offside body panels - and now the door shuts with the door lock and no masking tape to hold it together..... Snail like progress.
Jul 20, 2016 18:04:37 GMT
Busy with the rattle Can of Satin Black!
Jul 20, 2016 22:31:29 GMT
Err.............Wow!
Just spent the best part of an hour reading this tread. Makes my project pale into insignificance. Love it!
Thinking matt or satin black myself.
Couple of questions re the cage. Why isn't it closer to the roof and why no roof diagonal?
When are you starting the nitrous install? :-)
Last Edit: Jul 20, 2016 22:32:22 GMT by nalesutol
Thanks Alan - it is a far more "agricultural" project compared to yours! The cage was originally closer to the roof - well actually the roof was closer to the cage but at a late stage I had to raise the body 2" to get clearance at the back of the engine/scuttle and I will be putting a roof diagonal in next time I take the body off (But it is not for serious competition use) so no nitrous.
Thanks Alan - it is a far more "agricultural" project compared to yours! The cage was originally closer to the roof - well actually the roof was closer to the cage but at a late stage I had to raise the body 2" to get clearance at the back of the engine/scuttle and I will be putting a roof diagonal in next time I take the body off (But it is not for serious competition use) so no nitrous. I would hardly call it agricultural! With regard to the cage I did wonder if, as they say in the forces, 'no battle plan survives contact with the enemy' :-) As long as the cage is higher than your crash helmet the front bar won't be in your sightline. So, no nitrous, yet :-) Mind you, fitting gas to this would be a bit of a mission, with 12 separate carbs. Any idea on final weight and power? And don't call me Shirley, I mean Alan :-) Regards Steve
Sorry Steve - I thought it was Lotus Alan but of course I cannot spell! The Power is the standard XJ-S 300 BHP but that is with the very restrictive 40mm x 2 inlet to the air filter so with my 6 x 40IDA I would think 330 BHP is likely??? The weight will be around 1700Lbs again estimated.
Jul 21, 2016 12:22:16 GMT
Over 400bhp/ton will make it quite lively :-)
Sept 14, 2016 14:09:44 GMT
Despite the lack of updates I have been doing some small jobs on the "Mega B". Principally getting the rear wings to sit neatly and fixing the side lexan windows. However the seats do not fit and the roll cage is in need of "adjustment" so I will be doing some more welding soon - but the welder has been declared "SHOT" as the wire feed gave up (- when somebody else was using it).
Sept 22, 2016 12:50:56 GMT
There is going to be a frantic three days work on the BGT . I have to vacate my workshop space by next weekend as my job finishes.......Lots of bits to go on the "Bay".
eurogranada
Sept 22, 2016 13:23:48 GMT
There is going to be a frantic three days work on the BGT . I have to vacate my workshop space by next weekend as my job finishes.......Lots of bits to go on the "Bay". Was that expected or a suprprise?? Doesn't really sound like good news...although nothing like a hard deadline to get something done....
Sept 22, 2016 14:28:17 GMT
There is going to be a frantic three days work on the BGT . I have to vacate my workshop space by next weekend as my job finishes.......Lots of bits to go on the "Bay". Was that expected or a suprprise?? Doesn't really sound like good news...although nothing like a hard deadline to get something done.... Well my Company had been bought out by BCA in July. That is a PLC and they don't need a "Restoration Mechanic" on their books. So not totally unexpected and I am quite happy to retire gracefully now.
adam73bgt
Club RR Member Number: 58
Pro Jag "MeGa B" GT V12adam73bgt
@adam73bgt
Club Retro Rides Member 58
Sept 22, 2016 14:46:19 GMT
Hope you get all the bits moved in time!
Frankenhealey
@frankenhealey
Sept 22, 2016 16:44:29 GMT
I am quite happy to retire gracefully now. So more time to work on your projects then
