I have a long style manifold for a 6 cylinder m104 with a 39mm external takeoff comes with t3 flange, metal gasket and bolts £100
custom flywheel and clutch kit billet flywheel from cg motorsport with spec 6 paddle stage 4 clutch and cg pressure plate, rated to over 400 ft lbs - has the 60-2 trigger wheel machined into the back (this will fit the later m111 v6 engine as well) the clutch I think is 26 or 28 spline so will fit 190's , c250td etc etc
£275
m104 2mm decompression plate kit from ferriday engineering with brand new genuine mercedes head gasket kit £120
uprated m104 high tensile headbolts from turbobandit in sweden £80
w202 5 speed manual gearbox only 62k miles will fit slk's etc (its an slk part number) £200 ono
magnecour ht leads for all m104 engines £50 (only covered 200 miles)
i'll get pictures up lashortly
Gary
07515620141
£275
Gary
07515620141
