jabbo
soy un perdedor
Feb 25, 2013 19:56:43 GMT
Last Edit: Feb 26, 2013 22:10:45 GMT by jabbo
Feb 25, 2013 20:48:57 GMT
Hi...Nice wheels but not for me.
If you started with 6x15 et 44 and put 2" on the outside to make an 8" wheel they would work out at 8x15 et19 ( 44-25=19)
Good luck with sale
jabbo
soy un perdedor
Feb 25, 2013 21:28:03 GMT
Hi...Nice wheels but not for me. If you started with 6x15 et 44 and put 2" on the outside to make an 8" wheel they would work out at 8x15 et19 ( 44-25=19) Good luck with sale Thanks for that. Only going by what the previous owner told me. If I get the chance I'll measure them myself at some point.
Last Edit: Feb 25, 2013 21:29:24 GMT by jabbo
Ramonz
Feb 25, 2013 21:39:11 GMT
Hi...Nice wheels but not for me. If you started with 6x15 et 44 and put 2" on the outside to make an 8" wheel they would work out at 8x15 et19 ( 44-25=19) Good luck with sale I make that 44-50=-6
1972 RX2 Series 1, 12a - sedan
1985 RX7 Series 3 13b EGi - coupe
Feb 25, 2013 23:30:13 GMT
whos right et
Feb 25, 2013 23:40:08 GMT
et19
Just to clarify the maths..... keeping the same offset and increasing the width by 2" gives you additional inch on inside and additional inch on outside but the wheel has an extra inch outboard from the theoretical example so 44-25+ et19....simples
jabbo
soy un perdedor
Feb 26, 2013 22:11:43 GMT
We're going with ET19 I've amended the first post
Feb 26, 2013 22:40:52 GMT
I don't think that's easy reading so heres my attempt off set is the distance from the center of the wheel to the wheel mounting face. in this case, before banding 44mm or et44. the wheel has 50mm* added to the outside of the wheel. which means the center of the wheel has moved 25mm. so now the distance from the center of the wheel to the mounting face has changed and is 25mm less. so now et19. *ish. seeing as 2inch is really 50.8mm ;D
Last Edit: Feb 26, 2013 22:42:06 GMT by Al Ramone
whats the lowest you would take? pm me your number please
