Jan 18, 2007 15:27:13 GMT
Preparing the Merc for its MOT, it has a leaking downpipe at the gasket. We all know what a pig exhausts are, and to be honest I'd rather daub some zorst putty on it rather than mess about with rusted bolts shearing, etc. Will the MOT man kick up a stink? Or is exhaust putty / bandages MOT-friendly?
Jan 18, 2007 15:42:03 GMT
As long as it doesn't leak, I think it's okay. I've got tests on cars with bodged up pipes, including a gun-gum bandaged back box.
Mr S
10-4 Good buddy.
Jan 18, 2007 15:52:24 GMT
My MOT station didn't pass mine with the gunge on.... Said it wasn't an MOT standard repair! lol
Jan 18, 2007 15:53:43 GMT
Putty isn't too good near the engine where the exhaust gases are still hot, much more durable on back boxes.
If you use it, DON'T thrash the engine until you've had the MoT or you'll probably blow all the Gun Gum out!
Jan 18, 2007 18:07:51 GMT
Cheers chaps. I'll look at the bolts and see if they're of the shearing-off, rusty chocolate variety (I fear so). If it looks like I'll have a mare getting the thing unbolted I'll have to try and bodge it I suppose I could always make a "heat shield" to mask the bodgery ;D
Odin
Jan 18, 2007 18:49:50 GMT
I've got a years ticket with a fair sized hole caked in putty no problem.
lebowski
Hillman Avenger, Clan Clover
Jan 18, 2007 19:08:25 GMT
My Clan exhaust has four bean tins with healthy dollops of Hermetite on it and it passed the MOT fine.
spacekadett
F*cking take that Hans Brrix!!
Jan 18, 2007 21:15:44 GMT
The MOT book says it's only a fail if it's a 'signifcant' leak,a little one only a pass and advise. Other than that as long as it's secure you can have as much paste and bean cans as you like Like the bloke who took my refresher course said 'MOT is minimum standard to be on the road'!!
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
Jan 18, 2007 21:23:07 GMT
My MOT man put some on so I could get a pass!
B-8-D
down to one car!!
as long as there is no "significant leak" theres fec all they can do apart from "advise" ... si
Last Edit: Jan 19, 2007 0:39:53 GMT by B-8-D
st182
'yota man
For reference- recent tests on the micra test bed, has revealed the following results so far. Test carried out on rotten joint on flexi coupling: Putty on its own lasted a week. Putty with can round lasted about 6 weeks. Currently on putty, bandage, foil, bean can and 2 clamps cos it snapped in half. Will let y'all know how long that lasts (unless i managed to get it replaced before it fails again)
Dan '93 JZA80 '79 TA40 '99 SCP10
Bioshock
It aint hip to be square.
If it don't leak-They can't fail it
Almera GTI = ugly bird who turns out to be great in the sack = Win
Nathan
Club RR Member Number: 1
Exhaust putty and the MOT manNathan
@bgtmidget7476
Club Retro Rides Member 1
I did this a few years back but to stop the gum from coming off I put Manifold wrap over the GUM, job sorted and sealed.
mercmad
Jan 19, 2007 11:12:31 GMT
Split the front pipe off back by the trans,then undo the manifold off the head.you can drop the whole lot out the bottom and undo the bolts( 2 of them ) on the bench/floor /whereever. An oxytorch is the best deal for manifold bolts. When reinstalling the parts,Use high temp silicone on the head surface and the flange,it will outlast the car!. it doesn't go hard and if you wait for a day or so for it to set up,it will be perfect seal. I use it all the time on muffler joints too as it allows the pipes to slide together easily.If theres a hole in the muffler i just smear it over the hole,leave it for a few hours and the hole is sealled until I can afford a new one. By the way,never get gun gum or any other muffler seal in your eyes! it burns like hell.
