alright Right the car is a mk3 ford fiesta 1.1 and she has been stood for a while shes got a new starter motor, new exhaust and second hand battery. She was running fine before she was stood the problem is when i turn the key i get all lights on the dash like i should and when i go to turn it that last time theres Nothing at all not a blip. can you help?
polo6n1600i
All I need is WD40 & Duck tape!
battery doesnt have enough charge?
2002 Vw Polo 1.9 TDI sport - Daily Diesel 2006 Vw Passat 3.2 v6 estate - family wagon 1990 Rover Montego 1.6 LX - Project 41
its the same even with a jump tho
Check the small wire is on the starter solenoid and that the connections are tight and clean. If they are fine, check the small wire has a 12v supply when the key is turned to the crank position.
hkr91
Does the solenoid on the starter engage?
I've had a new starter fail on me, does she start with a bump?
i will check the connections tomorrow and no nothing happens atall with turn of the key just dash lights and don't have enuff space to bump really
Even with a jump if the battery is completely drained it may not start
I have lights heater horn all working fine and all at once if i so wished, but i hope the battery is not a f#@ked
If you have had it standing for a long while and the battery has completely discharged it can curse word it
hkr91
On the newer batteries you're not supposed to let the voltage drop below a certain level (can't remember what type) otherwise the cells begin to die.
Using a jump start box on my t4 just made it click, I had to start my passat and allow it to stabilise and then crank.
Deffo check the connections on both the battery and starter. Next, whip out the multimeter and see if your getting voltage to the terminal on the starter. I've been known to "bridge" a screw driver over the connections (now have a snap on "starter") of the starter motor.
Oh forgot to say cost co do bosch silvertop batteries for £50 for the xr2i so should be cheaper for your car. It saved me £50 compared to halfords
omega
engine siezed? stick it in gear and push it and see if it moves.
ta willowandmikey i will look into that
na there is compression 100%
check the earth on the gearbox and the terminals to the starter. Has it got a chipped key?? 94 on has oem imobiliser.
