Nov 23, 2012 20:12:27 GMT
So I'm getting a mk5 cortina estate on sunday and need abit of insperation as to what to do with it I'm thinking wide wellers and lowered, or banded steelies eventually and lowered, hubcaps and roof rack What ya got guys thi is the one in question
Nobody dies a virgin, because lifes curse word us ALL
MK2VR6
Mk2 Golf GTi 90 Spec
Nov 23, 2012 20:24:12 GMT
Bortaf's (from this very forum) old Mk5 cortina estate 2.3 Ghia S estate. Apparently was the last one known to the club and had been in ashes to ashes and Michael Caine film "is there anybody there?" Still on the road according to DooVLA, which can only be a good thing.
Last Edit: Nov 23, 2012 20:25:44 GMT by MK2VR6
Nov 23, 2012 20:56:10 GMT
leave it exactly as it is! its a cortina estate, it needs no more work.
Nov 23, 2012 21:17:49 GMT
Nov 23, 2012 21:18:12 GMT
^ This. It's in autoshite colours so it already looks perfect!
Nov 23, 2012 21:45:35 GMT
Last mk5 we ever raced.
Last Edit: Feb 6, 2016 5:48:21 GMT by chrism1
Nov 23, 2012 21:47:38 GMT
Leave it as is, that is uber cool and will stand out from crowd all by itself!
Stags, Range Rover Classics
hamps
www.medwayrscentre.co.uk
Nov 23, 2012 22:21:33 GMT
Last mk5 we ever raced. And mk5 my uncle owned circa 1987 This second pic is a Granada ^^^^^^^^^^ ;D ;D
Nov 23, 2012 22:32:14 GMT
FFS.. photobucket is now a curse word..I knew from the age of the pic summat wasn't right. anyhoo should be this owned until 1994 when it was punched in the side by a DAF lorry
Last Edit: Feb 6, 2016 5:49:10 GMT by chrism1
Macoli
Nov 23, 2012 23:00:33 GMT
First off, sort any rot within it - that front wing looks a bit crusty. Judging by the wheels, it looks like a 1600 - if so, then try to get a Saloon rear axle for it, they have a much higher diff ratio and so helps with motorway cruising. Decent shock absorbers would be my next move - I learnt to drive in one of these 23 years ago and they were soggy even then! - but harder springs will not improve matters when they are not controlled properly by knackered dampers. New-old-stock is better than worn-out-old-stock! Next, if insurance will allow, a decent exhaust mainfold and system - they're cheap enough. Then a twin-choke weber. That'll make it rapid enough to start worrying the TDi crowd.
Don't, however, f-muck it up by trying to emulate the VW scene - roof-rack, rust, overly-stretched tyres and too low to get a jack* under it - with something that's so obviously not...
*Remember this does not jack up on the sills with a half-scissors jack, but through the sills with the Ford-specific jack...
Last Edit: Nov 23, 2012 23:01:26 GMT by Macoli
Wanted: mk2 Cavalier front valence
Copey
Nov 23, 2012 23:02:21 GMT
get the steels banded and slam it, job done!
Last Edit: Nov 23, 2012 23:02:56 GMT by Copey
Cheers guys, I was going to get some lotus or escort steelies banded and drop it abit but not too much, just a suitle drop. The rack comes with it yeah there's some crot on the wings but there's new wings with it which ill probably patch she's a 1600 L
m ore than an inch (25mm in new money) will start to where insides of frt tyres(due to wicked camber) & cause it to follow ruts & white lines. as said for handling go for thicker rollbars & decent shockers, when time comes replace the axle end void bushes with decent poly ones (not cheepo floflex dobtfit ones). will await the flameing from the stance brigade (what would i know). get yourself on www.buysellcortina.co.uk
theres more to life than mpg & to much power is just enough.
Nice work mate, another one saved from being mindlessly being smashed to pieces. Ive posted this pic before, but I like it.Photo shop done by Volksangyl I believe. Would be very easy, and fairly cheap to get something like this done to yours.The long lines suit it. Ive lowered mine 50mm on proper springs, new standard shocks.As said above, needs uprated ones definatley.That was the plan, but it failed its last MOT on all four shocks, so had to get new ones in a rush!Will get proper ones soon.Also, it does wear inside tyres, as above, and I cant get a normal trolly jack under it, and it wont go on ramps very well, but, it looks dang cool!(I think anyway)
aPexi
Nov 24, 2012 10:50:54 GMT
The safest way to cut springs is wearing converse all stars while under the influence of alcohol.
Nov 24, 2012 10:58:30 GMT
cheers, danburger, you saved me digging the link out. I reckon the beige one only really needs the window frames/pillars blacking and that's it, it's already a distinctive thing. I like the brown one peckerman posted, never seen one like that before.
killerbee
Triumph Spitfire hardtop for sale plz pm for details and pics.
Nov 24, 2012 14:26:28 GMT
if only you happened to have a nice set of RS 4 spokes somewhere.....
bortaf
Nov 24, 2012 14:34:41 GMT
Saloons don't have a much higher diff, they are the same or very VERY close (IE 2.3 estate 3.45 saloon 3.44 diff). Exhausts , ashley do a not very good fitting but cheap zorst but they are for the saloon so the tailpipe will need altering/extending, shocks are allways worth changing and also the bushes!! there are loads under there so get new ones or polly BUT don't poly all of them just a few or it can cause stress fractures to the chassis. Just a twin choke on a 1.6 will make a small differance but in no way will it make it fly like a modern!, change to a 2.0, cheapest and easyest 35BHP you will ever find in one simple mod;)
It does jack up from under the sill NOT through it but personly I allways buy a cheap trolly jack and never use the standard pillar jack and I do meen NEVER lol As craig says any more than an inch will cause tyre scrub on the fronts through excessive camber, he knows his stuff.
Last Edit: Nov 24, 2012 14:36:25 GMT by bortaf
R.I.P photobucket
Nov 24, 2012 18:34:06 GMT
This is mine, sorry very standard
PHUQ
Nov 24, 2012 20:16:59 GMT
This is mine, sorry very standard Not always a bad thing- that's bally lovely
