Jan 10, 2007 20:16:26 GMT
cheers slater I have a stock at the mo, but I'm always faffing around with stuff! anymore thoughts on fuel pipe flaring for benzboy (fearing I have 'jacked the thread)? or are we all agreed that flaring isn't worth the effort?
rod
Jan 10, 2007 21:28:14 GMT
Thread 'jacking ,but allied to fuel pipe on Mercs ...I had to move the Tank on my 230coupe to allow the rear shocks to reposition when fitting my air bags . Couldnt get the large diam rubber fuel pipe anywhere! Ended up using copper 15mm household plumbing fittings ,and the best of the old flexy pipe I could cut out !The fittings have a swage where the solder sits ,which conveniently creates a good pipe seal using new jubilees .
Last Edit: Jan 10, 2007 21:30:41 GMT by rod
slater
Club RR Member Number: 78
Jan 10, 2007 21:44:11 GMT
Alot of stock high pressure fuel lines have no 'flare' so i just put 2 and 2 together to make 4 and say you don't need it!
Jan 10, 2007 23:42:30 GMT
Thread 'jacking ,but allied to fuel pipe on Mercs ...I had to move the Tank on my 230coupe to allow the rear shocks to reposition when fitting my air bags . Couldnt get the large diam rubber fuel pipe anywhere! Ended up using copper 15mm household plumbing fittings ,and the best of the old flexy pipe I could cut out !The fittings have a swage where the solder sits ,which conveniently creates a good pipe seal using new jubilees . Hydraulic/hose suppliers are the best place for this kind of pipe. I use Linden locally but there are plenty of places nationwide and teh prices are pretty cheap. Its also where I got the rubber section of pipe I needed for my monza petrol tank filler neck (cost around 50p) I have used without flares many times in the past without any problem but I normally make sure there is plenty of pipe going into the flexi and use two clamps. Although it is classed its as high pressure on a car, you are only really talking a maximum of around 3.5bar which is a lot less than most compressed air systems. Admittedly you don't want to risk the slightest leak from a fuel line at those pressures though. Unless you own a monza and then the fuel leaks came as standard thanks to the cleverely designed fuel rail
