mhuk
Dec 16, 2014 12:29:49 GMT
Hey Mate Great conversion!!! I'm doing the same conversion myself at the moment but at this stage without the turbo. I was hoping I could ask a few questions about the electrical side of things. Did you use the clutch and brake switch inputs to the ECU? Love the big brakes and aftermarket gauges. I hope that diff holds up!!!! Cheers. any help would be appreciated. Hi mate. Thanks. It held up well with a supercharger so fingers crossed. Not sure I understand what you mean about brake and clutch. I'm using the spitfire loom for lights ect. MX5 connected it's loom (cut down) only for the MS ECU. I'm not using the standard mazda ecu. I'm not sure the mx5 loom/ecu runs anything brake other then the ABS. More info/pic @ facebook.com/tsmod feel free to ask away.
Spitfire with a mx5 turbo engine
Merc W210 on veg oil running water injection.
Dec 16, 2014 14:35:44 GMT
Diff will be fine i ran a ca18det through one. They do spin one wheel alot mind bit that's half the fun. This conversion is nice and clean looking forward to some action videos
mhuk
Dec 16, 2014 14:49:09 GMT
Thanks MightyMork. It seemed to handle the SC ok so providing no hard starts it be OK :-) fingers crossed.
Dec 16, 2014 15:41:48 GMT
You should be fine, i had a stock spit 1500 diffbehind my ca18det (175bhp) and hard launches were okay. I ran a supercharged 1600 mx5 lump in my herald on a 1:3.63 diff with marina pinion wheel and abused that allot with no trouble. I did blow a stock 12/50 diff when i had a rotary engine. The diff was not really my concern it was the trunions i wasnt to keen upon
Yeah I had a look on FB Looks like its coming along really well. The stock ecu uses an input for the tail lights and a the clutch, but I guess if the MS units don't use them they cant be that important. Stripping the stock loom was one hell of a brain teaser though! Ive managed to get the motor far enough back and low enough into the chassis so I don't have to cut any holes in the bonnet. Then shortened the shifter by about 6 inches. It sure makes for a tight fit though. Hey Cheers for your reply, no doubt Ill be asking a whole bunch more questions as the conversion comes along.
Thanks again.
ferny
Club RR Member Number: 13
73 Spitfre with a turbo.ferny
@ferny
Club Retro Rides Member 13
It uses the brake switch for the cruise control. I'm running with the MX5 loom but using the Herald wiring for the brake lights. All is fine.
mhuk
Dec 19, 2014 14:46:58 GMT
Awww I see now. Mine has gone away for mapping and MOT.
mhuk
MOT today! Not heard anything so don't know if it's a pass! Rough tune to get to the MOT netted 166bhp at the wheels. Look ok ?
mhuk
Folks,
This is now for SALE. £2000 buys you a rust free tub and chassis which is ready for a mx5 engine / gear box. No engine ect just a bare car as I'm going to building something else.
Message me if your interested.
mhuk
