may 25th update:
changed oil - was going to change filter too but my filter tool wouldn't fit so will do that later.
Aligned rear hatch pins
checked and cleaned alloys - would like some later porsche ones but lack the funds at present.
so will use the originals. 2 good P6 tyres and 2 worn out tyres means I only need to replace those 2.
checked over the bodywork - really needs a new paintjob as when it was kept under cover (possibly for as long as 6 years), the cover chaffed against the body in some areas . I am hoping that a good tcut will improve this a bit. You can see some fading on the OS front wing and some chaffe marks on the NS rear wing.
If i can find the battery, I'll start the task of getting the car running again.
Waiting on an exhaust gasket from steve to finish the exhaust system.
