Jul 19, 2017 17:01:16 GMT
hi there
Maplins do a variable vr part number MFA 919D2 Regulator
Fit one into each circuit and then fine tune using the vr.
Run the engine until up to a known temp then adjust the vr to suit, same with the fuel gauge.
Should sort out your issues
cheers - mike
eurogranada
Jul 24, 2017 12:25:49 GMT
So I'm back with a little update. Life was a little too busy this week. I became uncle for the 4th time, my wife celebrated her 45th birthday and we're prepping for our family holiday that will soon come around... Still having ordered the parts for the solid state VR, I tried to find time to fabricate that. I built the VR last Friday evening. I couldn't before as the parts though cheap took a day or two to get to me. I had a quick think about how to do it so it would sit in the original location. And then I just went for it. Drilled a hole in the original VR housing, attached the solid state VR IC to it so it could function as a heat sink. To be sure I first verified the ground pin was attached to the IC back plate, which it was. I soldered the ground pin to the housing as well. Then I fiddled with the internals of the original VR board. Braking off the original contacts etc. Sanding the remaining stubs so I could solder to them. I attached the two capacitors and was then only left with soldering the IC pins to the matching contacts. This was fiddly as when closing the unit you do not want anything to touch anything it shouldn't. So short insulated wires with only short soldered ends were used. But the flexibility was a bit lacking and as you have no room for long wires they really were just long enough to get in place. With that done I tested the output. Switching on the 13,54 source there was no smoke or smell coming from the unit. Good first result. Next the multimeter said 4.99v steady. So that was a great second result. I then expanded the circuit on the bench to include the sender and the temp (ex fuel) gauge. I hooked the VR and sender to ground, the gauge to the 4.99v output side and the other end to the signal post on the sender to complete the circuit. I then put the 13,54 volts to the regulator input. With a cold sender the gauge did not move. A good start. I then took some warm tapwater, but the gauge failed to register. I then boiled some water and put it in a ceramic cup. I guess the heat being soaked up by the cup already lowered the temp quite a bit as the gauge read, but only just in the cold scale. Whereas Sam's test had shown water of 85 degrees on a 5v gauge feed to read 2/3rds of the way up on the same gauge. So I boiled some more water and added to the cup. The gauge rose some. I then just poured the water over the sender and it read some more. Ending up about halfway up the gauge. So that is at least encouraging. I didn't burn a single part, but have one spare of it all, so I can if need be redo it a second time. Now because of the things I told you about above I had no time with the car at all last week apart from one evening of testing the gauge with different signal wires etc. So I've not gotten any further. Next up is exchanging the sender in the engine and redoing the bench test. This to see where this sender would read on the gauge with water just off the boil being poured over it. This gives me the info I need to decide how to create the water temp circuit. As the engine ecu needs the right sender to switch the fans on in time (now again confirmed that they work, fans on half speed is indiscernible under the hood and in the car, both fans on full speed is when you first hear them) but the gauge might need the other sender to work correctly. This test should tell me if I can use one and piggy back off the feed to the ecu and feed that to the gauge. But there are more tests to do. In car tests: replace the VR, run engine up to temp and see how it reads with the gauge matched sender (if it even reads as it hasn't for a while) on the original signal wire. Next up replacing that signal wire with the ecu's dash feed wire. See if that changes the reading in any way. If the sender now reads on the gauge, than (depending on the prior test result of how much deviation there is between senders) a final test may be putting back the right sender for the engine and seeing the readings. If I do need two senders I'll then plumb one into my coolant hoses for the gauge. The bad part becomes if the gauge in the car reads nothing even when for instance pouring boiling water over the sender. And as the last in car tests reveiled signal on both the feed post of the gauge as well as the signal post but still no movement of the gauge that may well be an outcome to expect. I don't really know what the fix should then be. I could isolate the gauge from the cluster PCB and just feed it from the VR directly using a wire and a direct new signal line. I'm pretty eager to see and test, but the heat in the system also means testing is not easy. I've already had my hand sprayed with hot coolant (not burned though). It'll probably be a week before I know all I need to know. But at least getting a reading on the gauge would be a step forward. Before it went to max now it won't move unless grounded (as it goes to max again). Well how much can one person type about a damned VR/gauge circuit, lol.
mk2cossie
Club RR Member Number: 77
Jul 24, 2017 12:40:51 GMT
Very nice little update Eurogranada With regards to the temp sender wire going through the ecu to feed the gauge, is it the single wire one in the housing in the middle of the vee? As on the EEC IV the single wire temp sender isn't part of the ecu, and just goes from the sender to the instrument cluster plug. I can try and have a look at the EEC V wiring diagram and see where that wire goes to if you like? It may well just pass through the ECU itself and output straight to the cluster As for the temp sender to use, if it does pass through the ecu, I'd be inclined to use the original engine sender unit to match the gauge
eurogranada
Jul 24, 2017 13:06:56 GMT
Very nice little update Eurogranada With regards to the temp sender wire going through the ecu to feed the gauge, is it the single wire one in the housing in the middle of the vee? As on the EEC IV the single wire temp sender isn't part of the ecu, and just goes from the sender to the instrument cluster plug. I can try and have a look at the EEC V wiring diagram and see where that wire goes to if you like? It may well just pass through the ECU itself and output straight to the cluster As for the temp sender to use, if it does pass through the ecu, I'd be inclined to use the original engine sender unit to match the gauge Hi, The EEC-V ecu takes the single wire input for coolant temp from the centre of the V on the front of the engine. This signal is, as far as I´ve been told, used to (help) determine when the cooling fans come on. The ecu also has a feed to the gauge possibly through the dash cluster controller (a seperate orange unit between ecu and dash cluster) that I think also controls the switches on the electronic gearbox behaviour settings (sport, eco, winter). So I'm pretty sure the ecu does something with the sender signal. So this for me would be reason to use the sender that matches the ECU. Also to help my point along. I've only heard my fans kick in on max speed three times now. Once while testing with Sam, once on the alignment bench after 30+ minutes of idling and once earlier this week. Now, the first two times were on the new sender that matched the gauge and I always felt the fans came on very late! The engine was really hot. This week due to testing I had the original sender back in and low and behold I felt like it kicked in the fans much sooner. That is why I find repeating the bench test with the engine matched sender important. But feel free to prove me wrong. I just need more testing done before I can conclude what would be the best way forward.
Jul 24, 2017 18:08:20 GMT
I would test using a pan of boiling water & pop the sender in the pan. Consistent temp that way to check both senders with and the senders will cope with the heat no problem.
eurogranada
Yesterday while walking the dog I quickly changed over the senders. Took the engine matched one home and tested with boiling water. No reading on the gauge. I think it just minimally rose off the stop in the bottom, but that is it.
I'd like to conclude that it obviously has a completely different range to the other one. But, I had a hard time even getting resistance readings from it. Also the centre pin that the signal wire connects to could rotate. So maybe that sender is broken? I might have a spare in my other engine, but I might also have had to transfer it over at the time. For the cost, I might just buy a new one to be sure.
Meanwhile as the dash matched sender is now in the car, testing will continue with that and the new VR in place possibly tonight. Slowly but surely I'll get to the bottom of this.
eurogranada
I'm going to share something here that's pretty hard for me. But I want to as I both feel very melancholic about it all and it is on my mind constantly today. Also I consider you my digital family of sorts. Today marks the tenth anniversary of the day we found out my three year old daughter had cancer. Yes, 25-07-07 is a day I'll never forget... Our daughter had a cold or at least was a little short of breath. And after bathing her lips turned ice blue before any colour would return. So my wife went to our doctor and he prescribed some antibiotics. When 48 hours later there was no improvement she again took our girl to the doctor. This time she was seen by a temporary replacement. He didn't like the sound of her and took notice of my daughter being a premature baby (8 weeks too soon and too small for the term she was born at 1180 grams) so he referred her to the hospitals pediatrician. The pediatrician was worried as well and ordered a chest x-ray. And from there our life turned to $h!t for the next three years. Our daughter was breathing on 2/6th of her lung capacity through 1/3rd of her windpipe...Had we not gone to the doctor and ended up at the hospital, she would have not woken up in the next two days. Jeez, I can't even type this properly as vision is blurred an my throat blocked. Suffice to say that her treatment, although no expense spared, was one of the worst in 30 years of wordwide history. My daughter had every complication she could possibly get. But she fought and fought and fought. The chemo was extremely hard to get to terms with. Seeing your little precious girl wither away is hard...very hard and harsch. For 130 days we did not live at home, but in Ronald McDonald homes. Many a day we had good news in the morning, bad news in the afternoon. We've been close to lovingly letting her go for weeks on end. But despite having our permission, she wouldn't let go, she kept fighting. Today however I celebrate her conquering cancer. Beating the odds! Going from this (mind you rather graphic picture so skip if you need to. I'll put some space between this and the picture) To this (a lot less graphic) I'm very proud to be able to say she's doing well in life in general as well as school even upping a level despite having suffered some brain damage from her treatment. Tonight we celebrate by eating out! I don't mean to upset anyone, but this day grabs me each and every year still. As does the day in 2010 when treatment was officially done.
ade36
Glad there has been a happy ending to what must have been a horrific ordeal. I have used the Ronald McDonald house charities when my 5 month old (at the time) son was having open heart surgery. What they provide is so helpful at times like those, (so people, always drop your change in the boxes on the counter when you get your big mac... it really does go to a good place). I wish you and your family all the best for the future
Jul 25, 2017 10:07:17 GMT
My wife and I are both cancer survivors. My wife lost her left leg due to this cancer. I came out with some kidney damage. My wife had 3x cancer after and is in remission now after a very taxing few years just behind us. Buuuut we are all good now and loving life. Some dates on the calendar are hard to go past and little weird pains can really scare us both.
Enjoy your meal, take care, look after yourself and family.
Oh and by the way, only just to support Ronald Mc Donald I make it my job to eat at MCD as much as I can. Has nothing to do with the fact that I might like junk food at all!! I see this as a support thing!!
Do they still have the Mac Kroket??? I LOVE them!!
Jul 25, 2017 10:16:37 GMT
Thanks for sharing!, wish you and your loved ones all the best!
eternaloptimist
Thanks for sharing - reminds me what's really important.
Whilst I would not want anyone else to go through this - it's experiences like this that puts life back in to a real prospective - hope you all continue to bode well - Chris
eurogranada
Jul 26, 2017 10:29:22 GMT
And even more thanks for caring to you all!
Life has never been quite the same after this experience. Although now doing well, there's always the fear of this disease returning. But as long as we have no indication of that we won't think about it too much. But when she's ill or anything we still are more easily spooked.
In general my family is doing well. My wife is chronically ill but doing as good as can be expected and has been stable for quite some time now. I myself suffered a burn-out about 3 years back partly because of what happened to my daughter, but also because of the things I had to deal with regarding my wife and work. But I got very good care and have now been feeling better than ever (apart from an occasional mental dip over the restoration works). My girl is doing great for what can be expected and my boy is a joy to see grow and come into his own. Our marriage has also never been better...
So yeah, pretty happy really. Thanks for caring.
eurogranada
Now I just had to say I was happy now didn't I! Well I sure have known I did that. And I should have know it might become a jinx... So my day yesterday went a lot like this... Off to work as usual. It's a bit more quiet now it's holiday season so I was doing non interesting but necessary inventory work so I can update my AD domain. Boring stuff. Untill I get a call from my girl, in tears and audibly pretty upset. She'd fallen of her leased pony as it stumbled and hit the dirt with her head face first. Her cap had split so it was a pretty big hit. To make matters worse, the pony had rolled over her trying to get back up. So I calmed my daughter down not being mad over the now useless expensive cap as it at least seems to have done what it should have done. She complains of headache and two fingers that hurt one of which is a little swollen. They move but not full range. All the while I'm stuck at work. Feeling curse word about it all. Ok, she was responsive, coherent and such so no immediate need or danger, but just a rotten feeling to be stuck at work. I get her mom who is dependent on others for car transport to go check up on our girl with grandma. They find her doing pretty normal so a new cap is acquired and she gets back on the horse for a bit. When I get home, my girl also just arrives. She looks ok and feels ok but her headache is still present and her finger is still a bit swollen and sensitive. Due to her hospital trauma's we can't get her to come to the E.R. with us. So we taped up her fingers as I've had done myself a couple of times as well. Today thankfully the head ache is fully gone and her finger is less swollen and also hurting less while being more movable. So we're probably just fine... But still this event has impacted my own well being. Caused my own set of issues. But the day wasn't over now was it... So with dinner now behind us I thought it wise to walk te dog and take my wife with me for my next gauge test. So I had someone to read the gauge if I needed to do something under the hood. So we get there and I immediately start changin out the VR. I was trying to see if the known working sender with a direct line to the cluster on the new VR would give a reading. If not I'd add a direct ground to the sender to see if that braught life to the gauge. But the VR didn't fit as I somehow managed to mislay the bottom plate between checking it's orientation and actually fitting the wires to the contacts. I guess I'm just a dumb@$$. So back in with the old VR and I'm ready to test. I start up the car and proceed to put it in drive and roll it out on idle. I'm out and turn the wheel so I can make room for my wife to get in the car for the short warm up drive when she is frantically pointing and starts yelling that the car is leaking something. I stop and turn off the engine. Prepared to see red fluid from the steering rack dripping to the ground... Well what I say was the same red fluid, but it sure was not coming from the rack. It was way too much fluid for it to be that so the only other thing that sprung to mind was a ruptured oil cooler line. I open the hood and immediately confirm this is it. As they pass through the bulkhead to the cooler I checke these regularly for wear. But off course without any sign of wear one ruptured at a point I had not expected. Right below the hose clamp where the rubber line meets the hardline. The hardline was cut during the build to suit the needs but was sanded and deburred etc so shouldn't be sharp. But maybe the angle was too tight or something or the line just too old (as I think I used the original oil cooler lines) nearing 20 years of service. Anyway I had a huge mess to clean up and a car to get back into the garage by myself. Thankfully one of my friends lives about 500 yards from my garage so I called and asked for help. He came out with two old t-shirts and I had by now found some old but usefull still 3cm thick under carpet. I sacrificed this to soak up as much oil as possible and we cleand up after with the shirts. There's no hiding the event though, as oil and grease leave nasty stains... Well I tried to clean it at least. But of course I was again being a dumb@$$ and I didn't want to wait for my friend to turn up, so I had moved all 1400+ kilograms of the Granada a bit more out of the way by myself. Dealing with the bulge in the road and the bump at the garage entrance took too much out of me though and added to the tension I was feeling because of my little girl's day my body locked up. Now to find out what kind of hose is suitable for oil cooler duty as I have no idea of the pressures. I think it's an 8 or 10 mm ID hose with about a 20mm OD. It seems pretty thick walled. At least the fix isn't too difficult. It's just taking out the grille and swapping the hose (probably both at the same time). Ah the joys of parenting and owning a classic car.... Have a laugh fella's: Ruptured hose And the bloody mess
Jul 27, 2017 14:19:43 GMT
Damn, thats annoying! I had something similar happen, though that was my own fault in forgetting to tighten a hose clamp and dropped it all over a ceramic tiled floor, a little slippery! Can you not get the hose from a car parts place, it's quite low pressure really? Otherwise a hydraulic shop should be able to sort something for you, plenty of them around.
Hope your daughter is doing well, falling off a horse is all part of riding. I hit the ground more than once when I was younger. Helmets might be expensive, but worth it when you need them. The main thing is that she got back on and it didn't stop her wanting to ride.
Jul 27, 2017 14:46:03 GMT
Just been reading your daughter's story. Having a 2.5 year old daughter myself, I can't imagine what you and your wife must have gone through, only that this must be the most terrible experience for a parent. I read the story with emotion.
I was truly glad to read that your daughter pulled through it in the end. Thanks for sharing. This reminds us that, life is too short and too precious to worry about the unimportant stuff and that really we should concentrate on our love ones first and foremost.
All the best to you and your family,
Nick.
eurogranada
Jul 27, 2017 14:55:54 GMT
Damn, thats annoying! I had something similar happen, though that was my own fault in forgetting to tighten a hose clamp and dropped it all over a ceramic tiled floor, a little slippery! Can you not get the hose from a car parts place, it's quite low pressure really? Otherwise a hydraulic shop should be able to sort something for you, plenty of them around. Hope your daughter is doing well, falling off a horse is all part of riding. I hit the ground more than once when I was younger. Helmets might be expensive, but worth it when you need them. The main thing is that she got back on and it didn't stop her wanting to ride. Yeah that's all it is, annoying really, oh and hard to clean up. There's no water near the garage and no electricity either so we'll see how to best clean up after the holidays. I too have had the same thing happen before, on my Mustang. I was at the gas station on the hastelweg if you know it and just about to drive off after filling up on LPG when I lost all drive. Huge puddle on the rubberised tiles. Turned out the hardlines between the radiator and automatic had been split and joined with a piece of rubber hose. But as opposed to myself they didn't bother to clean the edges so there was a sharp edge chafing through the rubber.... That was at least a more convenient place! Yes, I think its more flow rather then pressure. But I've already checked and the hastelweg has at least one or two companies present that do hydraulic hoses etc. and of course also a motor factors, so I think I'll find something suitable. Like you say it's all just annoying but nothing major. I've checked in a couple of times today but she says she's doing fine. She only feels her fingers a bit but not as much as yesterday. She rode for another two hours today, but she avoided galloping so she's taken a little mental hit non the less. We hope to convince her that this was a fluke and that she can safely gallop around once more tomorrow. And yes, the cap did what it was there to do! So I'm not complaining too much about that. The extra spendings mean I have sacrificed a personal savings can but hey, that's what a good parent does, right? And I treated myself to the por-15 tank sealer so.... lol
eurogranada
Jul 27, 2017 15:16:15 GMT
Just been reading your daughter's story. Having a 2.5 year old daughter myself, I can't imagine what you and your wife must have gone through, only that this must be the most terrible experience for a parent. I read the story with emotion. I was truly glad to read that your daughter pulled through it in the end. Thanks for sharing. This reminds us that, life is too short and too precious to worry about the unimportant stuff and that really we should concentrate on our love ones first and foremost. All the best to you and your family, Nick. To you as much as any one else who read this, with or without commenting: Thank you for your support! It says a lot about you all and that I value a great deal. True, this has to be the worst thing I lived through. And believe me, you don't know the half of what the past 16 years have looked like. I won't bore you with any of it, but as much as has come on our path, the cancer in my 3 year old was definitely the worst. I still have a hard time with that. It's one of those things that you put away but never really accept. And that is even with our positive outcome! But the memories of seeing you child so vulnerable and you yourself being so powerless. The memories of telling her it's fine if she wants to let go because it's such an unfair fight.... well it's hard, still. I've never been the same person since. You'd think you'd learn to enjoy, to celebrate life, but I couldn't enjoy anything anymore. My beliefs were so turned upside down I just couldn't. The world instantly became the most unfair place in my universe. It took a burn-out and treatment for me to start to enjoy life a bit more. But at the same time it made me a better father I think. And I have my flaws, but I believe I'm a good man to all, but a great husband and father to my family. And I know I love each and every one of them incredibly much... And I know first hand there are so many others who have even more to bear than we do/did. So I cross my fingers and hope my life can stay as it is for a while and we can enjoy our upcoming (for the first time in 16 years) "adventurous" holiday together. Thank you for caring, again...
Mate you are a strong bloke. I have a great deal of respect for you and your family.You are doing a great job. Or in Dutch " Goed gedaan jochie"....
but to be honest I had a little bit of a giggle about your leak.... It's so typical and I am sure we all had a similar experience. My washed, polished, clay-ed, 535i dropped all it (gearbox) fluids on top of my sloping driveway.... Same as in your photo's oil everywhere. Did I chuck the #$@*& when it happened....
Take care
