stefan
If it isn't broken fix it till it is
Sept 15, 2012 17:17:18 GMT
So my next project is based on a scimitar chassis that I have had for about a year or so, its now in the garage.
My question is how strong is the axel as the motor I am thinking of useing has a mass of torque and a reasonable amount of power to go with it.
It will be hotrod ish, for now I will have to keep the axel for regestering it as a rebody but if it is not upto the job I will have to change it later on.
So how much power will it take.
POWER IS EVERYTHING WITHOUT CONTROL
1985 Honda jazz 1997 Saab 93 convertible 2010 transit 280
Sept 15, 2012 18:27:16 GMT
well, the general figure that gets thrown around is: "they're good for 500Bhp"
stefan
Sept 15, 2012 19:38:55 GMT
If thats the case it sould hold togeather ok
Scimitar axel how strongstealthstylz
@stealthstylz
Club Retro Rides Member 174
Sept 15, 2012 20:11:36 GMT
Yeah they'll hack serious power, know of a few that have been holding up behind 400+ ft/lbs big blocks for years without trouble.
stefan
Sept 15, 2012 20:19:42 GMT
Thats good that is getting close to the tourqe figure of the engine I want to use so it should be ok.
Sept 15, 2012 20:33:34 GMT
Thats good that is getting close to the tourqe figure of the engine I want to use so it should be ok. Ok, I'll bite. What is it? A lorry diesel?
stefan
Sept 15, 2012 20:56:13 GMT
No not a lorry motor a bentley 6.75 V8 turbo motor and box. They are powerful with very high tourqe and thats low boost so hope t wind it up a bit as well
Last Edit: Sept 15, 2012 20:58:17 GMT by stefan
Sept 15, 2012 21:34:26 GMT
No not a lorry motor a bentley 6.75 V8 turbo motor and box. Wow! Good answer.
froggy
Sept 15, 2012 21:58:13 GMT
The slush box gets the pounding not the diff in this case .
Sept 16, 2012 1:09:21 GMT
for the love of god, make sure the chassis is in tip-top condition before fitting that! The whole thing's only made from 2mm steel, which when made from perfect non-rotten steel, would struggle to stay in one piece at HALF that power level!
Given that most are 30+ years old, and live in the UK... there's not going to be much thick metal left on it
Sept 16, 2012 1:30:12 GMT
No not a lorry motor a bentley 6.75 V8 turbo motor and box. Wow! Good answer. Yes, a very good answer. ;D
stefan
Sept 16, 2012 8:03:58 GMT
The chassis is in good condition but I will be I think regestering it and then making the chassis alot stronger to cope. My main worry was the rear axel which sounds like it will be fine
Sept 16, 2012 16:01:36 GMT
By the way, which year the Scimitar axle is? They changed from Salisbury 7HA to 4HA somewhere around the SE5/SE5a transition.
Citroën DS 21 '66, Renault 16 TS '73, Scimitar GTE '74, Audi 80 '87, Merc 190E '88, Peugeot 205 GTI '88, BMW 735iL '89, Merc 230TE '89 , BMW 320i '92
Onne
Sept 16, 2012 16:55:03 GMT
Nothing like a bit of flex :-)
1990 Mercedes W126 300SE 1997 Mercedes W140 S320L
Sept 16, 2012 18:57:36 GMT
The chassis is in good condition but I will be I think regestering it and then making the chassis alot stronger to cope. My main worry was the rear axel which sounds like it will be fine I'm not sure what you mean by registering it, if the Scimitar is already registered. In any case, BIVA only really comes into play if you modify the chassis by removing material. If you add bracing, or a roll-cage, etc., surely that doesn't attract the attention of the authorities ?
stefan
Sept 16, 2012 19:40:59 GMT
I will need to register it as a rebody with a new name but will not need BIVA
stefan
Sept 17, 2012 16:09:37 GMT
Just completed the deal on the engine and box and payed for it, happy days
stefan
Sept 17, 2012 20:32:27 GMT
It will have a build thread, just looking for some 4 x 114 steel wheels in 15" flavour for banding
mikeymk
'85 Polo Coupe S 1.6 16v
Sept 18, 2012 7:14:09 GMT
4x114 15in? Isn't that Honda Accord / Rover 600 size..?
