Genuine solid g40, g40 alloys, weitec suspension, jabba r1 charger, jabba chip, jabba induction, 65mm pulley.
Few hundred miles ago it's had all upper gaskets and seals including headgasket, headbolts, all 8 valves relapped, stem seals, 8 new hydraulic tappets, cambelt, water pump, front pads, rear shoes, 2 new wheel cylinders and a new firestone tyre.
Inside the engine the bores are still like new and made even compressions after being built. Charger spot on and makes over a bar of boost.
Bad points are the seats have caught the sun, oil pumps worn and getting ready as the pressure is much higher cold (can get these quite cheap trade) gear selectors jammed on me before a couple of times and the exhausts been grafted from kitchen bin size to small, it's a bit noisy for me. Few cosmetic bits like a couple scabs on tailgate, odd dent and a chip on bonnet
Massive folder of history 11 months MOT 5 months tax. Located in Chesterfield £2000 or a px I would like a mk1 jetta but will consider others
Ricky 07525062929.
Ricky 07525062929.
