Jan 13, 2013 23:35:00 GMT
Plugs should be darkish grey, that means it's slightly rich and is safe for now. There are probably 2 set screws on each carb, 1 is for idle, this simply opens up the throttle a bit. The other is for mixture at idle, this can very well be this D shape key. Post a picture of the carbs you are using and I can be more helpfull. For now; if the screw is at the outlet of the carb it's a mixture screw, meaning turning out enriches the mixture. If it's at the airbox side it's an air screw meaning turning out leans the mixture (!). You will probably need to increase the main jet size as well as the idle jet. Sometimes you can increase fuel level in the carb bowls, this will effectively enrichen the mixture over the entire range, which is what you'll probably need. See if you can bend the small tab on the float that pushes the float needle into the housing. If this all sounds too daunting, you should start reading about motorbike carbs
pork
Thanks, il give that a go, along with increasing the fuel pressure.
Beings as the first set of carb kept on flooding, I dropped the pressure low down, so far as to now it doesn't even register on the fuel pressure gauge, but even then, that set of carbs still flooded.
So now I've replaced them with new set, but haven't raised pressure back up (so worth a go)
Referring to the fuel mixture d-shape key, which way do I turn to make it richer?
Thanks
Jan 14, 2013 11:25:50 GMT
For now; if the screw is at the outlet of the carb it's a mixture screw, meaning turning out enriches the mixture. If it's at the airbox side it's an air screw meaning turning out leans the mixture (!). There you go; airbox side>in=richer, cilinder side>in=leaner Instead of cilinder or airbox side, you can also say in front of or behind the throttle plate.
pork
Jan 14, 2013 11:33:12 GMT
For now; if the screw is at the outlet of the carb it's a mixture screw, meaning turning out enriches the mixture. If it's at the airbox side it's an air screw meaning turning out leans the mixture (!). There you go; airbox side>in=richer, cilinder side>in=leaner Instead of cilinder or airbox side, you can also say in front of or behind the throttle plate. Brilliant, many thanks Once snow has stopped il give it a go!
Jan 14, 2013 19:05:53 GMT
That would make a great immobiliser - a big straw next to the steering wheel.
Jan 14, 2013 19:20:31 GMT
Just read the whole thread and ilove it good on you for having a go a proper built not bought motor!
pork
Jan 14, 2013 20:50:00 GMT
That would make a great immobiliser - a big straw next to the steering wheel. Haha, I suppose it is get some funny looks tho
pork
Jan 14, 2013 20:50:17 GMT
Just read the whole thread and ilove it good on you for having a go a proper built not bought motor! Cheers
stevietuck
Never argue with idiots,they drag you down to their level then beat you with their expertise!
Jan 15, 2013 10:21:32 GMT
What i love about your build is your willingness to just have a go at everything, why buy it when you can make it yourself fair play to you mate keep up the good work. steve.
pork
Jan 15, 2013 13:19:09 GMT
Haha, thanks. This is the way I like to learn things, just throw myself at stuff and figure it out. Never used a welder before this build or worked on an engine. It's places like this that help loads though, so I'm very great full
Jan 15, 2013 13:59:51 GMT
I know that feeling cos I did the same... Almost never worked on a car before, apart the fluids changes, and now I completly disassembled the Volvo 164 and I'm making/doing all the things that need done by my self... and I'm learning has I go...
Nice learning topic... Keep it up...
pork
Jan 15, 2013 18:58:51 GMT
Thanks !! Last bit of the turbo puzzle arrived from America today, bit larger than I thought! I've put a £1 coin for comparison Turbo oil scavenge pump
stevietuck
Jan 19, 2013 11:00:39 GMT
Hey mate have you seen this???http://www.ebay.co.uk/itm/1990-Nissan-Micra-March-ST-Super-Turbo-Supercharger-Manual-p-x-recovery-truck-/140903349991?pt=Automobiles_UK&hash=item20ce7e7ee7
stevietuck
Sorry about the above i don't know how to do a link!! but you can get the ebay number from it cheers steve.
pork
Jan 20, 2013 15:54:25 GMT
Would love one!! If I can get mine to work with turbo properly, may consider strapping on a super charger too hahah
Jan 20, 2013 18:41:41 GMT
Same pump I've used for the last 7 years.
pork
Jan 20, 2013 18:44:49 GMT
Same pump I've used for the last 7 years. Did you get yours from America too?
pork
Jan 21, 2013 16:57:34 GMT
Made a drip accumulator for turbo oil return shizzle, Pipe that came with turbo Added compression fitting Made chamber thing from bits of exhaust and scrap Stick it al together and voila, Now just attach scavenger pump and return it somewhere convenient.
pork
Jan 21, 2013 18:17:22 GMT
Was just thinking, would I need some sort of breather on it?
Jan 21, 2013 18:24:03 GMT
Was just thinking, would I need some sort of breather on it? You might need one just on the oil reservoir because of the oil temp. changes...
