pork
Jul 31, 2014 14:49:59 GMT
Here's quick vid of first drive on public roads
I finally registered with tunerstudio so can now use the auto tune function
I take it you just plug in and drive with it? Feels like it's getting better the more I drive it
pork
Jul 31, 2014 14:50:10 GMT
Jul 31, 2014 19:56:27 GMT
I'm pretty sure that's what yoeddynz used on his Viva - drive and tune! *n
pork
on the old software you had to start a log file, go for a drive trying to put the load/rpm in every possible area of the VE map, afterwards run the log file through Logworks software which suggests changes to the map to correct over-lean or rich mixture, accept the changes to modify the msq file, then go out for another drive and hopefully the AFR is better.
Is Tunerstudio far easier?
clarke
Love this. Looks like a lot of fun!
Great to see you being able to enjoy it after all the setbacks with the 'charger setup and stolen parts.
Great effort!
pork
on the old software you had to start a log file, go for a drive trying to put the load/rpm in every possible area of the VE map, afterwards run the log file through Logworks software which suggests changes to the map to correct over-lean or rich mixture, accept the changes to modify the msq file, then go out for another drive and hopefully the AFR is better. Is Tunerstudio far easier? I'm useless with computer stuff, but I find his easy Plug it in, press start tune and drive it, and you can feel and watch it tune the ecu Then just press save to ecu
I see its American taxi cab livery is coming through the blue paint.
Click picture for more
froggy
Once your getting the map something like you can narrow the areas that autotune works on so I doesn't mess with parts of the map that work well .
You must be an engineer, with all those spare parts left over afterwards!
pork
You must be an engineer, with all those spare parts left over afterwards! Haha, true
joeytalent
ITB Everything.
I'm useless with computer stuff, but I find his easy Plug it in, press start tune and drive it, and you can feel and watch it tune the ecu Then just press save to ecu VEAL (the auto tune mode) will just try and tweak your VE table to match whatever you've put into the AFRs. It can get you pretty close - always worth checking to make sure it hasn't missed out any entries on the VE table though, so you don't have a huge spike anywhere. Its also worth doing the cold start auto tune next time you.. err.. start from cold. It will basically try and correct your Warm Up Enrichment (WUE) until you reach running temperature.
Colonelk
Club RR Member Number: 83
Loving the JDFI attitude to this. Nice to see it progress too
pork
Many thanks people And thanks for all the info too!
Tax has ran out now , so gotta wait few days before I'm back out with the laptop
stevietuck
Never argue with idiots,they drag you down to their level then beat you with their expertise!
Nice work bud looking good
pork
Aug 10, 2014 22:58:20 GMT
I like it with primer patches...
pork
Aug 15, 2014 19:28:53 GMT
pork
Aug 15, 2014 19:29:48 GMT
Done with rattle cans
Aug 15, 2014 19:59:38 GMT
Looks good in the pictures
