Jul 30, 2013 20:18:22 GMT
That vent is MEGA! Well done on that, looks like a complicated shape to make up, was it all mig'ed? Sounds ace too, you must be so pleased Please pop over to the Castle for a congratulatory ginger beer at RRG Kind regards, J
LowStandards
Club Retro Rides Member 231
Jul 30, 2013 20:41:25 GMT
I folded the bottom, front and back out of one piece, then added the sides, then made the 3inch ring and pieced the join between em, all migged, I do have a cracking mig though, my uncles a welder and he sorted me a murex... Lots off fiddly little bits of steel and lots of grinding, I've not ground it flush flush, just smoothish I'll wander over
Jul 30, 2013 20:48:24 GMT
What could I use the shield it? There's 5mm clearance max, would that shiny alu tape do it? yep, that's what I'd use, it's very sticky so won't come off, can't wait to see this at the gathering.
Last Edit: Jul 30, 2013 20:49:21 GMT by claymore
Jul 31, 2013 10:33:10 GMT
exhaust wrap for heat shield (if i can put my finger on my exhaust manifold with engine at running temp, then it must do something !) ISO standard repaired/modified car test - floor it, if nothing goes bang - jobs a good un! ;-) ISO999 standard
Paul Y
Jul 31, 2013 12:21:30 GMT
Just a thought, and probably a bit unwelcome after the work you have put in so far but....
What about mounting the intercooler on the bulkhead, next to the heater box and then ducting air into it through the inner wing? Seems, well from my keyboard engineer view, that there is enough room and it will take it away from the heat soak of the engine and the rad air.
But then again what do I know about pint size turbo engine requirements!
What ever, this is an epic build and is tempting me away from my beloved V8's to do something Kei powered and mental.
Looking forward to more video, keep up the good work.
P.
LowStandards
Jul 31, 2013 12:44:50 GMT
Hi Paul,
Its a fair point, its only really where it is as there's no room up front, to move it against the bulkhead will cost me ££££ in silicone and pipework, money I don't have (i'll have you know this cars cost me about £700 so far!!! (i'm tight) )
I figure - and I really know very little about turbos - the stock intercooler was pathetic, the new one is prob 4 times the core size, I can only hope that heat soak wont really present itself unless i'm stuck in traffic, in which case, i'm stuck in traffic so wont be speeding off anyways.
I might add some bonnet louvres at some point as long as they're subtle?
Jul 31, 2013 13:18:20 GMT
well thats why they were nicknamed interwarmers on imprezza/celica etc. in those cases, as far as i could oberve, air was travelling towards the engine, whereas you have done the reverse (although irrelevant i guess as your source is not the bonnet)
LowStandards
Turbos just died
I'm done
rysz
Rysz.
Noooooooooooooooooooooooooo!! Plenty of breakers on club cappo, don't give up now.
Koos
Mr S
10-4 Good buddy.
Man up and get it fixed - you've still got 2 weeks!!
You have to fix this, it's the only reason I'm going to the gathering.
LowStandards
I bought a new turbo, really eating into my driving her around dialing stuff in time!
Mr S
10-4 Good buddy.
Is it fitted yet?
keep going this is awesome!
You have to fix this, it's the only reason I'm going to the gathering. guilt trip much?? It worked thpugh so its all good!
Koos
LowStandards
You have to fix this, it's the only reason I'm going to the gathering. See now i feel bad, and there was me thinking it was to rag the wagon up the hill Fingers crossed it arrive sharpish, as a bonus its real easy to fit, wont take more than an hour to remove and refit. Then i can actually start driving her around
LowStandards
You have to fix this, it's the only reason I'm going to the gathering. See now I feel bad, and there was me thinking it was to rag the wagon up the hill
Fingers crossed it arrive sharpish, as a bonus its real easy to fit, wont take more than an hour to remove and refit. Then I can actually start driving her around Well, that as well
Waw, looks like something got chewed up in that.
