Recently refurbished set of Mim wheels here.
Bought from a Saab specialist thinking they would be 4x108 to go on a saxo, but i should have checked closer as they have 4x114.3 stamped in the centre. apparently very early saab 900's had this pcd. They are 6j
All 4 wheels are straight and have centre caps, although no badges, and only 2 retaining bolts are present.
the refurb looks pretty good generally although not perfect on the centre caps, hopefully you can see this on the pictures. The rim seems to be diamond cut and either laquered or clear powder coated (if this is possible?)
I'd like back what i paid for them, so £180 ovno gets them.
Located in High Wycombe, m40 J3/4
Can courier if required for probably £30ish. may be able to deliver as travel a bit with work, but can't gaurantee anything.
Michael
handleymyke(at)aol.com
Michael
