I am currently breaking a couple of 205 GTi's. 1st is a late 1993 ph2 Graphite Grey 1.9 GTi and the other is an early 1988 BE1 1.6 GTi.
Below is a list of the main bits I can think of right now, but name it as I may have it because I can't list absolutely every minor piece as I would be here forever.
Mechanicals:
1.6 front brake calipers. Perished seals. Complete with discs and pads - £20 the pair complete.
1.6 Front shocks and springs - £20 the pair
306 GTi6 shocks with autofive lowering springs and 205 topmounts - £30 the pair.
1.6 hubs. One bearing has play - £25 the pair
1.6 Driveshafts. Perished boots but rip free - £20 pair
Header tanks. Ph1 and ph2 - £10 each
Manual steering rack - £20
Subframe - £15
Fuel pump - £20
Front ARB with bushes and mounts - £10
BE1 1.6 gearbox - £50
BE3 1.9 gearbox. Has sheared mount so will need recasing - £30
1.6 flywheel - £10
1.6 cylinder head, complete but never run - £20
1.6 Block with pistons,rods, crank, sump etc. Never run - £20
Top ali engine mounts x 2 - £10 each
1.9 inlet manifold, injectors, fuel rail and FPR etc - £20
1.6 inlet manifold, injectors, fuel rail and FPR etc - £20
8v cam cover - £5
Powerflow stainless exhaust system - £100
Also got alternators etc
Interior
Electric window motors - £15 each
1.6 cloth front and rear seats. Small hole in drivers bolster - £50
Red carpet - £20
Red carpet centre console - £10
Black bare dashboards x 2 - £10 each
Many interior trims, enquire.
Seatbelt set front and rear with catches etc - £15
Ph1.5 door cards. Grubby - £10 pair
Speedo instrument cluster - £15
Very good condition black leather GTi steering wheels with centre GTi badges - £40 each.
BE1 gearknob and lift up sleeve - £30
Handbrakes, gearsticks, pedals. Enquire with requests.
Gloveboxes - £15 each
Fuseboxes - £10 each
Sunvisors, window switches, stalks etc. enquire with requests.
Exterior
Graphite grey front valance - £20
Graphite grey rear valance - £20
Ph2 black rear bumper - £30
Graphite grey tailgate. Slight rust under window - £20
Wing mirrors - £15 pair
Arch trims and red strips. Various so enquire
Quarter panel badges, various so enquire
Slated boot panels - £10 each
Door, windscreen and window seals, various so enquire
Window glass front, rear and sunroof - £5 each
I have loads more, that's a list from the top of my head giving it a quick thought. Effectively they will be stripped down as bare as people have the needs for, so whatever you are after whether it be a repair section cutting out, or the odd jesus handle - get in touch and I will soon tell you if I have it or not.
All prices are plus postage at reasonable prices. Collection is required on larger items and panels/fragile parts.
Unsure if I am allowed to put a contact number in here, so for now PM me if you need anything
Mechanicals:
Subframe - £15
Fuel pump - £20
1.6 flywheel - £10
8v cam cover - £5
Interior
Red carpet - £20
Exterior
