Aug 2, 2012 20:11:34 GMT akku said:
Dunno if its an old wives' tale but I was told the thing is not to engage OD when towing to prolong the life of the box.Heat build up is an issue but you can install an accessory trans cooler and fan if you think this is going to be an issue
Regular fluid changes with the right ATF will also prolong transmission life.
Yeah. Ours at work is a 2001, and has "Tow/Haul" mode, on a push-button on the end of the shifter. Keeps in gears longer and doesn't engage overdrive until about 50 instead of 40 with it off, and disengages it at the mere hint of pushing on the gas.
If that's what the factory mode does, I'd say there's truth to the tale.
Thrashed everywhere, our Ashtray does 18 US MPG, about 22 UK.
Driving position is horrible, everything else great. Dashboard is true GM parts-bin. Dull to look at, cheap to fix.
