Jun 29, 2016 21:36:08 GMT
As it turns out, this might not fit in the workshop we're using for the swap. When I say "might" and "fit in" I mean probably won't come back out due to the height and the size of the door.... Sent from too late to back out now using proboards What about swopping wheels for just old rims without tyres - would it then clear door ?
MonzaPhil
Think like a man of action, act like a man of thought
Yes we might have to fit something little, but where's the fun in that!
Sorry about the rear quarter panels, we were going to remove them, but since we haven't been asked for any in 8 years thought we wouldn't bother!
Ah well. Next time I get a 3 door I'll make sure to keep them.
Today is a brake pipey kind of day.
This is now a clicky linky!
Just cut a big enough hole in the side of the warehouse, drive disco out, cover hole with wood or if your feeling energetic get the magic sparky stick out and weld the metal back in place
MonzaPhil
Good plan, or perhaps just go for it and have an impromptu roof chop to amuse the RR collective.
MonzaPhil
Jun 30, 2016 17:41:08 GMT
Nothing dramatic today, I was pushed for time. Brake hose replaced (had to cut through old one). Now plumbed front to rear. The engine bay pipe system will just drop right in with its valve and stuff. Removed the last two redundant brackets too. Tow gear arrived in anticipation. I think Saturday is swap day. Measured workshop door height and we should be ok. Might have to let tyres down but we'll see. Fingers and toes crossed.
Jun 30, 2016 18:26:37 GMT
You could also removed springs and replace with blocks of wood etc to reduce height further if necessary.
MonzaPhil
Jun 30, 2016 18:35:57 GMT
That sounds like more effort than I want to apply *Bonus Storage Hedge picture...*
MonzaPhil
Well this could be going better.
Well this could be going better. I know it shouldn't, but this made me smile!
MonzaPhil
Right.
Why do I never make plans:
#1.. plans suck #2.. plans take up valuable doing time #3.. Some curse word always comes along and cocks it all up.
Etc. etc.
Today was simply a case of pushing the TD5 complete around to a neighbouring workshop, pop body off using his 2 post lift then swap chassis and lower body. What could go wrong?
Well, yesterday, aforementioned neighbour buggered off without remembering to give me his keys. No keys, no workshop, no workshop no 2 post lift.
I will not be defeated.
MonzaPhil
Anyway, work ceased officially at 12:30 and Matt With The Sport Range Rover had finished messing about with that (pics later) so our 4 post was empty.
(We had an aborted attempt to lift it using a digger and some string..... )
Turns out, no matter how shonky the method, there is NO way to carry out this operation in our workshop.
We do, however, have an outdoors, some barrels, some pallets, some offcuts of skirting board, a selection of wheels and the largest trolley jack I've seen.
I also had 3 volunteers expecting a 30 minute body swap or the postponement thereof.
I think you can see where this is going....
A & E? Hope not..... Nick
fer4l
Testing
Club RR Member Number: 73
1994 Land Rover Discoveryfer4l
@fer4l
Club Retro Rides Member 73
Surely a sufficiency of helium balloons would've seen it sorted in pas du temps?
MonzaPhil
Just for you guys who have requested it, and as an aside from what I was actually going to post.... How I anticipated the body removal..... [/URL] Yes, a flock of Disney bluebirds (or ducks according to the picture) gently seperating the body from the chassis with a cascade of glitter and dust (mostly rust) floating to the ground in celebration. Then when fitting the replacement body..... [/URL] Chuck Norris bird angels suspending the TD5 shell with beams of pure light and Norris energy before guiding the body mounts in to a fanfare played by an orchestra of woodland animals (not illustrated). I suppose you will want to know what actually happened.......
I suppose you will want to know what actually happened....... I am sitting here, avec cold San Mig (so no real rush), on tenterhooks. So yes, yes I do.
fer4l
Testing
@fer4l
Same, but with tea (it's only a time difference thing, the principles are all the same
As above! Though injeeping with the beverages, mines steong coffee :-) Cmon man, was it robins instead of bluebirds? Or flying reliant robins even?!
MonzaPhil
Can I get away without using MS Paint?
Can I get away without using MS Paint? No.
