Gem
East Midlands
Thanks for all the advice, serious and otherwise! looking at the front springs they only seem to have four active coils, so chopping a whole seems a bit drastic! Gem - did he say why? Those lowering springs look good and cheap, worth a punt I reckon, thanks Gem. The springs on a kangoo are different at the bottom as they are to the top so they wouldn't sit level and would be more likely to move, whereas on a bmw there the same all round which is why it's more common. He's a mechanic/mot tester and said it would fail an mot if they were to be cut. You'd be better off going for the lowering springs that someone else posted.
Last Edit: Jul 3, 2012 20:52:07 GMT by Gem
hairymel
avatar by volksangyl
Club RR Member Number: 207
you can always weld the bit back on.... just to add fuel to the fire, i have welded a broken spring back together* it lasted 8 years and was still in one piece when the car was scrappaged RR wouldn't be the same without a cut spring debate every six months * not an ideal solution ;D
whats that burning smell?
oh curse word :-(
will
/\ /\ /\ HERO ;D
Google tells me the fronts are regular on the kango and only the rears are pigtails, a quick peek at them in the metal would tell for sure. I've a set of cheepo clamps that have been used many times with success, wouldn't let my kids near them mind... In situ with cheap clamps and a grinder is silly dangerous and something I wouldn't relish doing again, the vibration made my clamps twist and it was somewhat of a surprise when the spring uncoiled!
RR wouldn't be the same without a cut spring debate every six months It has been about 7 years since I was involved in one I think. For the curious, Clamped with these: On the car Angle grinder On a jack Someone else The first time.
Yup
crappy clamps = bad incorrectly used clamps = bad
part of this hobby though is to have the right kit and know how to use it.
I'm going to treat myself to a hydraulic compressor some time.
I also need to get a plasma cutter.
And a bigger workshop to keep it all in...
hairymel
Thanks for sharing your experience Mr Hotwire my take on it - crappy clamps.. are crappyOn the car.... MM safe working practiceAngle grinder.... standard cutting toolOn a jack..... you weren't under the car but mind your hands/feet (don't ask yow I know )Someone else.... MM safe working practice ;DThe first time.... my first time there was blood and tears . . but I got over it I think we have reached the conclusions : everyone has an opinion proper lowering springs are proper lots of people shorten standard springs with no real adverse effects (depending on the vehicle) you need to be careful when cutting springs always use the best tools available to you, and use them safely Bruce takes cool pictures play safely and be happy people
Last Edit: Jul 4, 2012 8:36:16 GMT by hairymel
oh curse word :-(
bortaf
Thanks for sharing your experience Mr Hotwire my take on it - crappy clamps.. are crappyOn the car.... MM safe working practiceAngle grinder.... standard cutting toolOn a jack..... you weren't under the car but mind your hands/feet (don't ask yow I know )Someone else.... MM safe working practice ;DThe first time.... my first time there was blood and tears . . but I got over it I think we have reached the conclusions : everyone has an opinion proper lowering springs are proper lots of people shorten standard springs with no real adverse effects (depending on the vehicle) you need to be careful when cutting springs always use the best tools available to you, and use them safely Bruce takes cool pictures play safely and be happy people Well that pretty much ends the thread great post ;D The thing is there is a differance between what I would do myself and what I would recomend to somone elese, I know my level of incompetance not anyone elses I hurt myslef daily (anyone want a pic of the battery that blew (IE exploded) its top off nect to me whilst on charge yesterday cos me mate was grinding a bolt,,, 20 foot away in another room! and the wee acid burn on my top lip?) it's game I play called get home, get in the bath and count the "ouchies" ;D
Last Edit: Jul 4, 2012 12:15:45 GMT by bortaf
R.I.P photobucket
I have to admit that if there's a single job I hate doing, it's taking Mac struts apart. A guy I know told me a story (which I think was a lie) about a spring getting away from him and punching a hold through the roof of the workshop.
I'm been umming and ahhing about cutting a coil off the springs on my Audi 100 for weeks. The Audi forum are dead against and I'm not sure either. Suspect I'll wimp out and buy a set of springs in the end.
Jaguar S-Type 3.0 SE
I did know someone that pulled the retaining pin out of the back a triumph transverse leaf spring while his head was under the wheel arch.
Its not easy to smile with a wired jaw!
BTW dear lovely mod people, why is this post in the tech section? I was asking for style advice not tech!!
Last Edit: Jul 4, 2012 16:18:42 GMT by mdh
Koos
It turned into tech
i made my spring clamps when i was about 13 as a metal work project at school ,still got them still use them never had any problems with them,main thing to remember is not to stand inline with the coilover just in case, used them today on the escort half a coil out all round:)
mirafioriman
My next project.......
Cut springs are a cheap option and they can work, however, it's a bodge job. If lowered springs are not available 'off the shelf' there are several companies which can supply custom made springs to your specifications. Another advantage is you don't damage the originals so you can refit them if you wish.
I'd really like to cut off the bottom spring pan and fit one of the weld-on coil over conversions.
That way i could play with spring rates and ride heights easily and cheaply.
Koos
10mpg
Club RR Member Number: 204
Just to add my two pence worth, i will never cut springs unless they are have a spring seat deigned to fit a cut end, like early mustangs...
On 99% of cars i disapprove of spring cutting, i certainly would never cut them in situ professionally or personally, i don't think it's horrifically dangerous, but cutting something under tension is just not good practice..
There's nothing wrong with screw spring compressors providing they are of sufficient quality and properly designed, preferably with two points of contact at each end, this said it should be a no brainer that you use decent tools not cheap knock offs to do a safety critical job, i have used screw type compressors for years professionally as have several garages i know personally, the point of a hydraulic spring compressor is speed not safety, these only become necessary when doing many spring changes to save time, plus these can be just as dangerous if used incorrectly...
When i lower a car on coils i will invariably buy proper lowering springs, that way i can be secure in the handling and safety characteristics of the car, plus to me i will only lower a car to improve performance (i like the look of a lowered car, but wouldn't bother unless i was upgrading the handling/dampers/bushes ect at the same time) in fact many of my cars end up with completely upgraded suspension, but only a very very small drop in overall height
Coilovers are FTW in many of these situations..
Took a look at my springs yesterday. Renault seem to have built in an automatic lowering system, clever little stylish Frenchies. The system is very simple - they build the springs from second rate monkey metal and after twelve years they crack coils on their own!
Koos
mirafioriman
Broken springs are quite common now, when I fitted Lorinser lowering springs to my Merc W126 I discovered both rear coil springs were in fact broken. I have seen many quite new cars fail MOTs because of broken springs or need them replaced. Another benefit of fitting lowering springs you get new springs which are less likely to break, for a while at least It's like brake discs, on old cars you change the pads and the discs last virtually forever. On newer cars discs have become just about a service item!
I cut the springs on my old 306 years back. Lopped one coil of the bottom of some lowering springs, the bottom three coils were touching when in the strut and it sat in the bottom exactly the same as it had before. I never had any issues. Saying that I wouldn't do it again, springs are cheap enough, lower end coilovers are cheap now too. I can see the issue if you have a car that these parts aren't available/made for though..
will
Unexpected car time on Saturday gave me the opportunity to drop the newly purchased 309. I've just searched that auction site and the cheapest coilover kit (and remember it's torsion bar out back) is 570 which is way, way out of my league. I'm sure cheaper kits can be sourced for around the 200 mark though that's still beyond justification for a non essential (as in the car will work without it) car part. That leads on to lowering springs at a shade over 60 quid, trouble with them is they drop 35mm and I had a 5 inch arch gap to content with which would entail cutting a fair few coils from the new springs anyway. So Saturday I dug out the clamps and proceeded with the same caution as I (and many others) have done before. It's like many aspects of mechanics, especially home mechanics where a certain degree of improvisation is often involved. Proceed with caution and a eye for detail and all is good. I love free lows
Raoul Duke
Club RR Member Number: 117
Titanium strip on the mudflap and job's a good 'un ;D
...a redder shade of neck on a whiter shade of trash...
Jul 10, 2012 11:15:11 GMT
Mine are the screw type, ive had them about 15 years and they've been fine, got wide, double hooks on though and a square ratchet drive hole in the end so they are pretty secure and they have clamped down some big springs over the years withoyt bending or slipping.
