PhoenixCapri
West Midlands
Club RR Member Number: 91
1978 Mk2 Capri - new rimsPhoenixCapri
@phoenixescort
Club Retro Rides Member 91
How did you work out the difference in exhaust pipe length? Thanks as for the length of the pipe, I could have done it properly at work with a CAD based 1D model.... but in the end I used 'engineering judgement' Sent from my GT-I9305 using proboards
Really enjoyed reading this build - simple, understated, but with some lovely details. The only thing I'd say is that the front end looks like it's missing something - a detailed badge in the grille, maybe? And for a bonus, some acoustic engineering! I'm an audio engineer, so that I actually loved that bit. How did you work out the difference in exhaust pipe length? Hi, Lauren, the "other half" here I agree... there may have been comments as the grill was being done about replicating the detailing on the rear logos about whether the front should match. I'll be honest... I wanted it to! I suspect it's going to be one of those fiddly little detailing upgrades down the line that might transform the front end of the car!
May 15, 2014 11:51:54 GMT
Hi, Lauren, the "other half" here Hi Lauren, glad to hear the Capri went through its MOT smoothly and you get to enjoy the fruits of your (and Andy's, here and there :-P) labour on the road at last...! Welcome to the forum at last as well!!
PhoenixCapri
West Midlands
@phoenixescort
Not much to report on this one. It's all been going surprisingly well, and has even been doing Lauren's commute without issue - until Friday that was...
No idea how the nuts came loose, but the down pipe parted company with the manifold leading to much noise! Not the end of the world as it only took a few minutes to bolt back together with a new sealing ring.
Having a big leak did highlight that the exhaust may be restricting performance a bit - I suspect the reversed center box that probably isn't flowing all that efficiently in its backwards orientation.It seems it's time for a better flowing box, hopefully I won't make it stupid loud.....
I bet it sounded awesome!! If a bit loud... Good job it didn't fall off completely and get mangled!
Are you going to fabricate your own silencer from scratch or pull one out of a scrapyard??
Its good to hear its going nicely, the sign of a job well done I think!!
PhoenixCapri
West Midlands
@phoenixescort
Jun 21, 2014 19:42:43 GMT
Flipping paint! So when the car was all finished, the paint on the passenger door looked like it might have sunk a little. No biggy we thought, can polish that back. But seems some of the paint below the top coat on this door was a bit nasty - and after a few days in the sun it got worse, much worse! Basically whatever rubbish paint was hidden underneath hasn't actually set, and once it's got hot and then cooled, the top coat has slowly been cracked apart. The only solution was to pull the door off, get the paint stripper out and take it back to bare metal - joy! Has anyone else found that nitromors is now rubbish? Anyway, -it's now with the painter, so hopefully some time next week it'll be back on and the car will be looking as good as it should. Thankfully this was a second hand door so the rest of the car should be safe - fingers crossed! Why is nothing ever easy?!
bobman
Jun 21, 2014 21:06:37 GMT
its hateful when that happens, it can be part of the fun of working on older cars unfortunately, make you sick in the stomach at this stage of the job, and yes Nitromorse has changed its curse word, think its now VOC compliant, there's different coloured labels for different strengths but I just use stuff I get in the hardware store, no brand on it just paint striper
Last Edit: Jun 21, 2014 21:07:11 GMT by bobman
EmDee
Committer of Autrocities.
Club RR Member Number: 108
1978 Mk2 Capri - new rimsEmDee
@emdee
Club Retro Rides Member 108
Jul 18, 2014 21:47:36 GMT
yes Nitromorse has changed its curse word This x 1000 Think they're worried about it getting drunk by babies or some curse word so they made it harmless and therefore useless. Soul destroying to get setbacks like this but ultimately it'll make you a better person* Keep at it mate! * might not do this
Last Edit: Jul 18, 2014 21:48:04 GMT by EmDee
1978 Mk2 Capri - new rimsChasR
@chasr
Club Retro Rides Member 170
Jul 19, 2014 11:34:06 GMT
Noooooo! It is a real shame when these things happen! Still, it will be good to see this back out with its shiny coat of paint once more.
Soooo, will this Cappa be making an appearance at RetroWarwick?
PhoenixCapri
West Midlands
@phoenixescort
Jul 19, 2014 21:24:13 GMT
Cheers guys, it was a right pain, but all sorted now and my painter friend has done a great job Will probably head over to retrowarwick so long as nothing comes up, look forward to seeing you there - how's the Stag? On the Capri front, well other than it being shiney again the only thing to report is that we managed a camping trip to Cornwall with only one issue (cracked manifold which was welded up on the way) and the car held up great, works surprisingly well as a camping car. But the hills of the south west did highlight that a more torquey enging is badly needed, so will be keeping my eye out for something - probably a Sierra DOHC to start with, since it doesn't need to be fast, but would be nice to make it a more relaxed cruiser! Anyway, have some photos from what must be one of the best campsite views in the country
Jul 22, 2014 11:49:36 GMT
blimey those views aren't half bad are they!!
Glad to hear the Capri made it down an back without too much trouble - that exhaust manifold was well and truly cracked though!
Apart from possibly a new engine, are there any more plans for this Capri or is it just general maintenance and crack on with the other one now??
Jul 22, 2014 14:24:39 GMT
Great thread....really need to start a proper one on my 924 instead of a half baked one I have now
Jul 22, 2014 14:37:41 GMT
DOHC I4 could be a good shout, nice little engines those.
Campsite view is gorgeous, what campsite is it if you don't mind me asking?
conair
Jul 22, 2014 16:35:38 GMT
Second the I4 Shout, really underated lumps, if it's torque you want they have it.
Stunning car by the way, really looks the buisness, real creadit to all your hard work, hat's off sir.
Oct 28, 2014 16:00:28 GMT
DOHC I4 could be a good shout, nice little engines those. Campsite view is gorgeous, what campsite is it if you don't mind me asking? Way too slow on the reply here, sorry, but the campsite was Trewethett Farm, near Tintagel. It's now a Caravan Club site (aren't they all?) but it's still got the stunning views from the camping field. Word of warning though - they won't let you camp if it's too windy!
PhoenixCapri
West Midlands
@phoenixescort
Well step one is complete - we have an engine No ecu/engine bay loom sadly but it was cheap enough, just need to find the other bits and knock up some mounts
PhoenixCapri
West Midlands
@phoenixescort
Jan 11, 2015 19:58:38 GMT
Capri in non V6/V8 engine upgrade shocker! I know, making a sensible Capri seems somehow wrong doesn't it! Well after a couple of hours spannering we've got the engine out Heck of a large hole to fill! In other news I've liberated what I hope are the missing bits from a scrap Granada, so hopefully I've got everything I need to make it run now. Fingers crossed. Now to try and get the new engine in, how hard can that be?!
conair
Awesome, so is the 8v long term dude or a stop gap?
PhoenixCapri
West Midlands
@phoenixescort
Jan 14, 2015 10:10:04 GMT
Longish term I guess is the best way to put it. To be honest we'll see how this drives and if it's doing ok mpg and is pulling well enough it'll probably be there a while.
