Interesting Engine Baysrustingdeathtrap
@GUEST
Nov 21, 2006 23:09:56 GMT
I'm currently back into cleaning/smoothing engine bays... Trying to work out what I can move or remove from this : To clean it a bit,.. need to get the workshop manual out and give it a bit more thought. Fuel pump can be replaced with an electric one. Dizzy and coil can be replaced with mapped ignition, hide the coil pack down by the chassis rail. Battery in boot. Washer bottle under wing All pipes, wires and cables re routed to either run along chassis rails or behind inner wings. After that lot all you should see is an air cleaner, head and block and a master cylinder, which you could relocate under the dash if you wanted. Just to keep it on topic, heres mine.
Anglia68
Powered By Boredom.
Nov 21, 2006 23:39:16 GMT
Napier-Railton Y12.
Last Edit: Nov 21, 2006 23:40:48 GMT by Anglia68
Nov 21, 2006 23:57:00 GMT
antdat
my engine bay is not very interesting at the moment but it will be soon
archieboy
Volvo Amazon 2 door
Fuel pump can be replaced with an electric one. Dizzy and coil can be replaced with mapped ignition, hide the coil pack down by the chassis rail. Battery in boot. Washer bottle under wing All pipes, wires and cables re routed to either run along chassis rails or behind inner wings. After that lot all you should see is an air cleaner, head and block and a master cylinder, which you could relocate under the dash if you wanted. Oooh Thats the sort of answer I like Moving the pipes around is the bit that I'm trying to work out,.. Wiring isn't too bad and battery in the boot is a definate job to do anyway.
Nov 22, 2006 10:21:53 GMT
Nov 22, 2006 10:23:15 GMT
Nov 22, 2006 10:23:33 GMT
mercmad
Nov 22, 2006 11:58:04 GMT
Hisso racing engine.Made from a WW1 Hispano suiza V8 aeroengine. Cut in half and raced on the dirt in the USA in the 1930's....
bstardchild
Club RR Member Number: 71
Interesting Engine Baysbstardchild
@bstardchild
Club Retro Rides Member 71
Nov 22, 2006 12:16:15 GMT
Interesting hmmmmmm - define interesting Why would that be interesting - Cable ties are pretty much holding it all in - I threw it in and had it running after a marathon 27hr stint - It has 243 bhp replaced one with 167 bhp (the bhp doesn't have to work so hard as the interior is just as spartan ;D - been planning it for 4 years (engine swaps aren't just bosh it in) Oh and I love it - love it a lot
mercmad
Nov 22, 2006 12:45:07 GMT
EMD V16 ( 4000HP) real mussel..... ;D ;D the lever in the foreground is for revving it up..
Nov 24, 2006 22:15:26 GMT
I know the pic is small but I think its a supercharged straight 6 jag engine in a Mk2 Granada My brother saw it at the ten of the best show this year and took a pic on his phone. Its a supercharged V8, based around the LS1 format, obviously with quite a few non standard parts Latest format images1.fotopic.net/?iid=yk1fcj&outx=640&quality=70
diff
Engine by of Jo's viva
diff
Engine bay of my mk2 cortina
Hey, is this yours? Took it at CARS
Last Edit: Nov 25, 2006 0:35:24 GMT by Lewis
diff
yep thats mine alright.
Nov 25, 2006 11:10:53 GMT
Tis a fine motor! ;D I was really impressed by the wrapping when I saw it, as well as everything else! Lovely engine bay
Last Edit: Nov 25, 2006 11:11:08 GMT by Lewis
Nov 25, 2006 11:27:09 GMT
I'm curious, what is it? Those exhausts look 2smoke to me, triple as well, is it one of those 1970s Kawasaki engines? Or am I really missing something?
"Jeremy Clarkson, a man we motor enthusiasts need on our side like Lewis Hamilton's F1 car needs a towing ball and a Sprite Musketeer" My motor
