Jun 12, 2012 15:30:08 GMT
bigrod
Jun 12, 2012 16:06:21 GMT
Balls of steel award over here please!
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
breng
Jun 12, 2012 16:46:55 GMT
Jim, you must be a very brave man to take this on.
I am on my 4th SD1, I thought mine was a rotbox until I saw your pics.
The bolt on panels are'nt a problem, on one of these I am wary of the panels at the front like the inner wings and windscreen surround, especially if the rot has spread to the bulkhead / heater plenum.
Are you handy with the welder? I really hope so!
Good luck - I am sure you will enjoy yourself.
ShaunOfCalder
Yes - I should know better....
Jun 12, 2012 16:58:40 GMT
Ooooh! You're a brave man, that's a fact!!! Best of British with this project!
Another bloody Mx5 The wifes' Suzuki Grand Vitara Mercedes Sprinter Ambwilans (Rescue Unit)
Jun 12, 2012 16:59:57 GMT
Blimey - you appear to have consumed the world stock of brave pills. ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) That's a big project you've got there, but the end result will undoubtedly be worth it. ;D
Jun 12, 2012 17:10:54 GMT
Yeah this is going to be a big and long project. The chap i bought it off assured me that "just fit 4 doors and ill be halfway there". My mate and i curse word ourselves laughing at his optimism. On the way home I stopped at the services on the M25 to check the ratchet straps were still tight. I noticed that the trailer bed had turned orange/brown from all the rust that had fallen off the rover. Still, it weighed a bit less which helped my fuel economy.
I'm pretty good at MIG welding, but I'm going to invest in a spot welder, as i want this put back together looking as factory as possible.
Jun 12, 2012 18:37:56 GMT
Good luck with your project, it will be good to see the updates.
We are all individuals.
Jun 12, 2012 20:47:15 GMT
I remember seeing this on ebay. You're in for some hero welding with that one I recon. Have you just got rimmer bros to send you one of everything from their SD1 section?
Looking forward to seeing what its like when you get it stripped down.
hairymel
avatar by volksangyl
Club RR Member Number: 207
Jun 13, 2012 14:17:06 GMT
good luck ![;)](//storage.proboards.com/forum/images/smiley/wink.png) i love welding threads ;D
whats that burning smell?
oh curse word :-(
Jun 13, 2012 14:43:16 GMT
bookmarked lets see the strip down pics soon balls of steel to take that on good luck fella
Jun 13, 2012 16:50:17 GMT
Jun 13, 2012 17:06:20 GMT
Also found this badge under the drivers seat which indicates this was a Lancashire Police car. ![](http://i.imgur.com/DQXK87Q.jpg) A bit about SD1 police cars.... what i know so far anyway. Because the general public used to complain when they saw the Police driving round in luxury barges, they all appear to be low specification. They don't have sunroofs, they have manual window winders and mirrors. They don't have tinted glass. They have vinyl boot trim instead of carpet, and there is no carpet on the door cards or wood trim, and no wood trim on the dash. Mechanically they have the carburettored V8 engine which is standard, but they have heavy duty clutches and bigger bearings in the gearbox. The brake setup is the same as the Vitesse with 4 pot dual circuit front calipers, vented discs, and the rear drums have smaller diameter rear brake cylinders unique to police spec cars. The dampers are standard, but the springs are 20% stiffer but original ride height. They usually have manual steering racks, but mine is power steering. Some forces disabled the power steering as it gives better feel at high speed. Some cars had Vitesse alloys, some had standard 14" alloys like mine. Most had non chrome trim bumpers, but a few came with chrome trims, over-riders, headlamp washers and front fog lights. This is the info i have gleaned so far, as i go on I'm sure ill find out more. Basically big engine, low weight, big brakes, stronger drivetrain. When police cars were cool.
Jun 13, 2012 17:26:01 GMT
Cripes, that is some project you've got yourself there sir...!!! Where was the motor stationed during its crim' catching days...? Although this will take a ton of work I just know it'll be worth it... Get stuck in and let's see what transpires... Now get working or you're nicked... ![;)](//storage.proboards.com/forum/images/smiley/wink.png)
***GARAGE CURRENTLY EMPTY***
Jun 13, 2012 18:12:30 GMT
Not sure where it was stationed. The number plate suggests it was registered in Kendal or Preston.
Jun 13, 2012 20:56:40 GMT
Very much looking forwards to this.
It's going to look cracking when its finished, best of luck!
Rob
'55 Austin A30
'71 MGB GT
'72 Datsun 240 shed
'72 Mercedes 240D
'79 Firebird
'86 Austin Maestro Van
'91 Mercedes 250D
'91 BMW e34 535i Sport
'92 Mazda MX-5
Jun 13, 2012 23:19:54 GMT
D---GEC IS aug 86 preston, so that would tie in with your lancs badge.
theres more to life than mpg & to much power is just enough.
dbdb
Jun 13, 2012 23:56:20 GMT
I'm glad to see an SD1 being saved. Lots of work, but worth it! ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) David
bstardchild
Club RR Member Number: 71
good luck ![;)](//storage.proboards.com/forum/images/smiley/wink.png) I love welding threads ;D Yeah why is it we like them again OP - 127884696429694 / 10 for the save Double RR points for it getting finished (which I have no doubt you will do as others have said you've obviously taken the world stock of brave pills and have enough to last you the time it takes to complete the project)
Yeah it will get done, as i have to vanquish the demons of scrapping the first one. But i cant promise its going to be quick!
93fxdl
Enter your message here...
Possible urban myth, but in the day some cars were supposedly fitted with minilte wheels to stop brake fade Ttfn Glenn
