Here's a better image of a Herald/Spitfire diff.
In a Triumph they are mounted to the chassis using bushes in the rear eyes and also the bracket that is bolted to the nose. Front bracket could be remade to suit. The leaf spring is clamped down to the top of the casing so this area is also very strong and could provide an alternative mounting point if other suspension was being used.
Very early Herald diffs are quite weak in the stock application so choice of ratios with the later ones would be 4.11, 3.89, 3.63 or 3.27.
Here's some more info.
www.canleyclassics.com/?xhtml=xhtml/infodatabase/diff.html&xsl=infodatabase.xsl
You'd want to avoid a Type A but anything else ought to easily handle the power of an Imp engine. If you desperatly wanted to save weight you can get an aluminium housing too.
www.canleyclassics.com/?xhtml=xhtml/product/tkc220a.html&xsl=product.xsl
A second hand 4.11 diff could probably be had for £20....
