I beleive that the bell housing pattern is deifferent due to the extra width of the V6 block.
Either way, a pinto gearbox is no good for a V6 as the input shaft isn't long enough. The V6 shafts are slightly longer to allow the end to locate in the crank bearing. Otherwise it won't last 5 minutes.
